| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1986,
1994
Make: Ford
Model: Bronco II,
Ranger
Engine: 2.9, 2.3
Class: 4x4, 2wd
Used For: Winter driving and wheeling, keeping me broke and being a project. DD, project street truck
Rep Power: 5 ![]() iTrader: (0)
I was reading about the 8.8 explorer swap, and i have a couple of unanswered questions. im not really concerned about the 28/31 spline difference, i just want the ease of a dirrect bolt in, as i dont trust myself welding on an axle. do the 8.8 ranger axles have disc brakes? how common were the ranger 8.8's, common enough to find in the junkyard? the major reason i want the ranger 8.8 is for the limited slip diff. for the winter months that are quickly approaching.
Tweet
#2 |
Year: 1996
Make: Ford Ranger
Model: XLT 4x4
Engine: 4.0L V6
Class: Serious Bolt On 4x4
Used For: DD, Rearranging the Landscape
Rep Power: 18 ![]() ![]() ![]() ![]() iTrader: (7)
Yes the Ranger 8.8 is dime a dozen in the junkyards.
And 7 out of 10 will have Ford's Trak-Lok limited slip. I wouldn't trust a junkyard one to actually working like it should however, so buy a rebuild clutch kit as well. As far as disc brakes, most will not. IIRC some FX level 2's might have had them...but like I am said I am unsure. Not having disc brakes is why many owners look for the explorer 8.8's since they have them post 1996.
__________________
'00 Ranger on '96 TTB frame/drivetrain |
Tweet
#3 |
Year: 1986,
1994
Make: Ford
Model: Bronco II,
Ranger
Engine: 2.9, 2.3
Class: 4x4, 2wd
i'd rather have the drum, dont really wanna run brake lines lol, im accumulating quite a junkyard list
Tweet
#4 |
Premium Member
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Rep Power: 55 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
I've found that less than 50% have the L/S but that really varys per area. Only Rangers that come with the disc brakes are the 2011. I'm also one that is happy with a good set of drums on a stock truck.
Dave |
Tweet
#5 |
Year: 1986,
1994
Make: Ford
Model: Bronco II,
Ranger
Engine: 2.9, 2.3
Class: 4x4, 2wd
well maybe i'll get lucky and find one with 3.73's and L/S, if not im sure i can find one with the 8.8 and i'll just get a lockright
Tweet
#6 |
Premium Member
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Used For: Project, DD
Rep Power: 23 ![]() ![]() ![]() iTrader: (2)
I got an explorer 8.8 with 3.73's and limited slip for 100 bucks and had the perches welded on at a shop for another 100 bucks. After that it shoudl just bolt in and you don't have to run brake lines for the explorer.
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights. 84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers. |
Tweet
#7 |
Year: 1986,
1994
Make: Ford
Model: Bronco II,
Ranger
Engine: 2.9, 2.3
Class: 4x4, 2wd
so once the perches are on theres no other really difficult modfication?
Tweet
#8 | |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Quote:
Around my area the prevalence of limited slips seems about 30% or so. The axle was made 2" wider in '93, so you'd want to stay with these axles ('93-'09) if you have a '98.
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#9 |
Premium Member
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
As far as I can tell I haven't seen anything that is major. Of course I haven't thrown mine in yet but the e brake cable might require a little mod like a hole drilled or something (not to bad), last I checked the brake lines were close and atleast no hardline mods, you have to get larger u bolts and spring plates and the shock mounts also need put on.
The only thing I am not sure about is the rear sway bar.
__________________
Tweet
#10 |
Year: 1986,
1994
Make: Ford
Model: Bronco II,
Ranger
Engine: 2.9, 2.3
Class: 4x4, 2wd
who needs sway bars? lol, but that dosent sound too bad, a project always seams more difficult before you start i guess
Tweet
#11 |
Year: 1990
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 4x4
Used For: holding down the driveway
Rep Power: 32 ![]() ![]() ![]() iTrader: (1)
spring perches and shock mounts are required
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears! Send e-mail instead of PM, box full... |
Tweet
#12 |
Junior Member
Year: '95~'00
Make: Ford
Model: Bronco~Ranger
Engine: 5.8~4.0
Class: 4x4 Extreme
Rep Power: 8 ![]() iTrader: (0)
If a person was going to go to all the work of swapping ales and moving perches and tabs for shocks I would go ahead and put in a 9" and be done with it. Putting the VSS behind the t-case would only take a few extra steps and cost a couple hundred more but in the long run you are way stronger and have no c-clip's.
I guess breaking so many 8.8's made me dislike them, any more if I am playing with axles I go bigger. |
Tweet
| Bookmarks |
| Tags |
| axle, explorer, limited slip, range |
| Thread Tools | |
| Display Modes | |
