- Sep 23, 2011
- Charlottesville VA
Hey guys, i just posted this over in the new member section but, i think this is a better location for the post. I just picked up a 98 b2500 with 176k and cant figure some things out.
Background:
The truck is VERY clean and i am the third owner. Its paint and interior are literally spotless with alomst no leaks. The clutch/flywheel/slave cylinder were replaced at 170k. The owner before me (he was the second owner) really did not do much maintenance during his ownership (first owner however took it to the dealer every 3k). So, i have been playing catch up on the maintenance that he skipped. When i purchased the truck, i noticed that it had a pretty rough idle, slight hesitation, major pre-detonation "pinging" under load and was a bit sluggish. So, last weekend i replaced:
-The oil and filter with fresh 10w-30
-New fuel filter
-New air filter
-New plugs and wires (all 8)
-Changed all fluids (rear diff, manual trans, coolant, brake and power steering)
-Cleaned the mass air flow, added seafoam treatment to a full tank of fuel and used seafoam spray directly into the engine.
All of which really made it run much better. No more pinging, and really smoothed it out. However, i have some questions.
1) The top end has some valve train noise which is not too loud but, is noticeable. The previous owner added lucas and it stopped the noise but, i don't use many additives. Is slight valve train noise normal? Ive had cars in the past that made tons of noise but, never hurt anything.
2) It still idles really rough but, once you increase the rpm's it runs great. Warm or cold like clockwork it idles rough. Almost shakes the truck side to side. However, when the engine is cold, it feels like it wants to bog and stall when starting off in 1st gear. any ideas? (going to clean the IAC and EGR tonight to see if it helps)
3) I cant tell if the timing belt, tensioner , and accessory belt have been replaced. Any tricks or hints to see if its ever been replaced?
4) I just noticed the the truck has 2 leaks. One where the dip stick tube meets the block and one where the actual dip stick enters the tube. Are there replacement seals for this?
Sorry for the lengthy post but, thanks in advance!!
Background:
-New fuel filter
-New air filter
