Go Back   The Ranger Station Forums > Styling & Electrical > Communications
Notices
Communications This forum is for CB & HAM radio, cellphones, PDAs, in-cab computer installations and GPS.
Post New Thread Reply
Thread Tools Display Modes
Old 09-20-2011, 08:37 AM   #1
schneiderz
schneiderz's Avatar
Year: 2003
Make: ford
Model: ranger
Engine: 2.3 4 cylider
Class: 2WD Off-Road
Used For: daily driver & Off Roading
schneiderz is an unknown quantity at this point
Default very little noise from cb
Hey I have a browning 62" whip on my truck and when anyone calls me on my cb I can barely hear them. My buddy has a 5 ft firstik on his bronco and has the same problem any ideas?
__________________
03 ford ranger xl 4 cyl with 3 inch body lift and 31 inch m/ts
schneiderz is offline   Reply With Quote
Old 09-20-2011, 03:25 PM   #2
02RangerXLT
02RangerXLT's Avatar
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold02RangerXLT is a splendid one to behold
Default
What CB do you have?
Where is your antenna mounted?
What type of antenna mount are you using?
What type of coax do you have?
__________________
Click --> 2002 Ford Ranger 4x4
Quote:
Originally Posted by 7.5L_STX View Post
Huked on fonikz workded good fer me!!
meh, :kicks dirt: :walks away:
Quote:
Originally Posted by rrbrian222 View Post
Somewhere, a village in Kenya is missing its idiot.
02RangerXLT is offline   Reply With Quote
Old 09-21-2011, 12:33 PM   #3
schneiderz
schneiderz's Avatar
Year: 2003
Make: ford
Model: ranger
Class: 2WD Off-Road
Default
its a midland 1001z, the antenna is attached to the toolbox in middle, windshield mount with a 5" spring, and i think its a 9 ft cable
__________________
Old 09-21-2011, 02:51 PM   #4
02RangerXLT
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
Windshield mount?
__________________
Old 09-25-2011, 10:50 PM   #5
schneiderz
schneiderz's Avatar
Year: 2003
Make: ford
Model: ranger
Class: 2WD Off-Road
Default
its mounted on a toolbox using a rearview mirror mount
__________________
Old 09-26-2011, 08:10 PM   #6
02RangerXLT
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
Is your toolbox actually bolted (into the bed rails) to your truck bed or is it just attached with J-bolts or some of those goofy Kobalt mounts?
__________________
Old 09-27-2011, 08:18 AM   #7
schneiderz
schneiderz's Avatar
Year: 2003
Make: ford
Model: ranger
Class: 2WD Off-Road
Default
The box is attached with j bolts but the box is mounted directly on the metal there isnt anything between the two metal surfaces
__________________
Old 09-27-2011, 03:18 PM   #8
02RangerXLT
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
That's not a good enough of a ground... There isn't any true bare metal touching (You have paint and clear coat creating a layer in between). You'll either need to attach it with some bolts to the bed, attach some ground straps from the box to the bed, or get a NGP setup. The NGP setup being a last resort, since it isn't as effective.
__________________
Old 09-28-2011, 08:09 AM   #9
Milton
Junior Member
Milton's Avatar
Year: 2009
Make: Mazda
Model: B2300
Engine: 2.3L
Class: 2WD
Used For: DD; Support Public Service Events; Emergency Communications Support
Milton is on a distinguished road
Default Time for some basic trouble shooting
Start with some basic troubleshooting by answering the question, "Is the issue with the transceiver or not." You need a CB watt meter and a 50-ohm dummy load to see if your transceiver is transmitting. Configure your radio as follows:
CB_Transceiver===COAX===CB_Watt_Meter===COAX===Dum my_Load
(connect the transceiver to the watt meter using a 3 foot length known good coax, then connect the watt meter to the dummy load using another 3 foot length of known good coax)
Try transmitting and the watt meter will tell you if your transceiver is functioning. The Midland 1001Z should transmit a whopping 4 watts of power, does it?
Milton is offline   Reply With Quote
Old 09-28-2011, 10:54 PM   #10
schneiderz
schneiderz's Avatar
Year: 2003
Make: ford
Model: ranger
Class: 2WD Off-Road
Default
I have talked on the cb with it. The problem is that when it gets to the other cb it is really quiet
__________________
Old 09-30-2011, 09:56 PM   #11
Milton
Junior Member
Milton's Avatar
Year: 2009
Make: Mazda
Model: B2300
Engine: 2.3L
Class: 2WD
The Midland 1001z is an AM (amplitude modulated) radio. This means that the transmitter carrier wave varies in strength in proportion to the volume of the transmitted audio signal (your voice) and how quickly the carrier wave strength is varied matches the frequency of the transmitted audio signal. So to transmit a good quality signal the radio needs to put out a well modulated high power signal.
Sounds like you do not have a lot of test equipment so let's try this. Find a buddy with a good working CB and take your radio to where his radio is. Then:
1) Make a radio test on his radio, to prove that his radio is working.
2) Disconnect the coax cable from the back of his radio and connect it to your radio.
3) Make a radio check with your radio.
If your radio does not pass, then the issue is with your radio.
If the radio does pass then the issue is either your installation or antenna system. So then back at your truck, are you getting the expected 13.8 VDC to power the radio? Check this when you are transmitting. If that is good then the issue is with your antenna system which is defined as everything from your radio's coax connector to and including the antenna.
You have to be systematic, so now we are trying to determine if the issue is with the radio or not.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
