| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1999
Make: Ford
Model: Ranger XLT SuperCab
Engine: 4.0L OHV
Class: 4X4
Used For: 2nd vehicle / truck stuff.
Rep Power: 8 ![]() iTrader: (1)
So I just ordered some ceramic pads. With the rotors, either getting them resurface (probable) or replaced (depending on their condition). My question is is there anything else I should check or looked at while the rotors are off? 99 4wd 4.0L automatic
__________________
99 Ranger XLT 4DR 4wd 4.0L OHV, Auto. Build Thread http://www.therangerstation.com/foru...d.php?t=110443 |
Tweet
#2 | |
Year: 1994
Make: FORD
Model: RANGER SUPER CAB
Rep Power: 14 ![]() ![]() iTrader: (1)
Quote:
don't forget to clean and lube the caliper slide bolts with good brake grease too!!! |
Tweet
#3 |
Year: 1998
Make: Ford
Model: Explorer
Engine: 4.0 SOHC
Class: 4x4
Used For: daily driving, fun in the snow
Rep Power: 14 ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Ya I put some stop squeak in my caliper slide bolts lol. Better then nothing. My front end is finally 90% fixed and back to stock except my front drive shaft... I suspect a pinion seal is causing leak since it's right from where it connects to diff.
__________________
1999 Ranger 4.0 4x4 Off Road http://www.therangerstation.com/foru...d.php?t=103611 <--- My Slow Build Last edited by bilzy7; 09-20-2011 at 09:40 AM. |
Tweet
#5 |
Year: 1998
Make: Ford
Model: Explorer
Engine: 4.0 SOHC
Class: 4x4
I know... Lol. I shoulda used the grease from my grease gun at a minimum... Its easy to change so... I guess I will soon... Lol
__________________
1999 Ranger 4.0 4x4 Off Road http://www.therangerstation.com/foru...d.php?t=103611 <--- My Slow Build |
Tweet
#6 | |
Year: 1994
Make: FORD
Quote:
just stop at autozone, they sell brake grease in a little one use packet for like a dollar or two, pull the pins, clean them up real good, and grease them up. don't use regular grease, the heat will dry it up and cause the caliper to hang up , much like that stop squeal is going to do |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
