| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Communications This forum is for CB & HAM radio, cellphones, PDAs, in-cab computer installations and GPS. |
Thread Tools | Display Modes |
#1 |
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Used For: Literally everything.
Rep Power: 19 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Finally going to bite the bullet and get this thing working. I've narrowed it down to two options:
The antenna will be mounted behind the cab on a toolbox. The Wilson 1000, Base mount, so the coil is under the roof ![]() Removable coil base so i can use the car wash ![]() No rear visibility problems ![]() Won't block 3rd brake light ![]() Signal will be partly blocked by cab ![]() The Wilson 2000, Mid Mount, 18" long 3/8" stand will put coil just over top of roof ![]() Removability issues? ![]() Shaft might block view, window seam does anyways? Will partially block out 3rd brake light ![]() leverage might bend up my nice new tool box or damage something else? ![]() ![]() ![]() Signal completely unobstructed by cab ![]() ![]() ![]() Thoughts? Experiences?
__________________
"The difference between genius and stupidity is that genius has its limits" - Albert Einstein Never give up: http://www.youtube.com/watch?v=Y6hz_s2XIAU 1984 Ranger - std cab, long bed: The Deathtrap 302; T18; D20 Tcase; 6' lift; 4.56 gears; 33' pro comp MT's; Aussie locked rear 1997 Ranger - std cab, short bed: Red Ranger 2.3L; M50D R1; 2wd; 4.56 gears; Explorer 8.8; ARB locker; 235/75R15 AT's (soon to undergo 4x4 conversion |
Tweet
#2 |
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Rep Power: 21 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
The Wilson 1000,
Base mount, so the coil is under the roof Removable coil base so i can use the car wash No rear visibility problems Won't block 3rd brake light Signal will be partly blocked by cab I have experience with that set-up. Mine squeeled every time I keyed the Mic. I stuck it to the aft cab roof and it worked great, but trees tended to knock it over in the woods, which is where I primarily used it (hunt club) The Wilson 2000, Mid Mount, 18" long 3/8" stand will put coil just over top of roof Removability issues? Shaft might block view, window seam does anyways? Will partially block out 3rd brake light leverage might bend up my nice new tool box or damage something else? Signal completely unobstructed by cab I think this setup will squeel too. I don't think having the coil midway up is going to give you an unobstucted signal like you think it will. I ended up using a different Wilson, but I can't recall its model name/#. Smaller magnetic base and smaller coil, like the 1000, but half the height. It worked "ok" when stuck on the cab roof.
__________________
If at first, you don't succeed, RTFM. |
Tweet
#3 |
Junior Member
Year: 2004
Make: Ford
Model: Ranger Fx4
Engine: 4.0
Class: Fx4
Rep Power: 5 ![]() iTrader: (0)
Have you thought about a firestik
__________________
2004 Ranger Fx4 33x12.50 Goodyear DuraTracs On 15x8 Dc-1's 40 Series Flowmaster 3 Inch Body Lift |
Tweet
#4 |
Year: 1984, 1997
Make: Ford
Model: Rangers
Engine: 302, 2.3
Well the 2000 seems like a normal Wilson just mounted on a post. The post doesn't do any of the transmitting or receiving.
I'm really not too keen on a roof mount of any type. Absolutely no holes are going to be drilled in my roof, nor do I feel like having a cable hanging around. Have one on Deathtrap. Too stiff and I want something a little more slender for the highway driven Ranger.
__________________
Tweet
#5 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Get the 2000, a 3/8" rod isn't going to obstruct your vision any more than a bar on a sliding rear window equipped pickup. It won't block the third brake light worth a crap either... the block would be negligible. Also, Shouldn't bend it. Just get a "heavy duty" stud for it... should be larger than a normal stud.
__________________
Click --> 2002 Ford Ranger 4x4 |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
