2001 4.0 with P0401 egr code
A. Wayne
10+ Year Member
Ok- I quickly checked the vacuum lines going to/from egr sensor, and unplugged line to valve. With the vacuum line unplugged from the valve, I can feel pulses of vacuum coming from the line at an idle. Any thoughts on where to go next? I don't know if the sensor is sending enough vacuum to the valve, or if it is sending vacuum at the right time. I plan on taking the valve off, cleaning it and trying to manually operate it to ensure it isn't siezed. Should I just start throwing parts at the truck? And most imprtantly, how do I clear the code? Just unplug the battery, or do I need a scanner, or can I use a jumper wire betweeen some of the ports on the scanner port on the truck?
I have the same error code, low EGR flow. I swapped out the EGR valve and the light came back on. After a couple of days the truck wants to stall out when I shift through neutral. I can feather the throttle and it runs smooth while in neutral. I don't know if I should change out the EGR solenoid and keep working through the EGR system. The neutral stall seems like a vacuum leak kinda deal, but I dunno'. I know lots of folks deal with the PO401 code-any ideas?
I replaced my whole EGR system before checking to make sure I didn't have any carbon build-up. Bad mistake because it would have saved me a bunch of greenbacks if I did.
Before...
After two cans of throttle body cleaner...
Well now I no I can go for a long ass time without having to worry about my EGR system. :D
Here's a link to some DPFE sensors... http://www.rockauto.com/catalog/x,carcode,1372711,parttype,5088
