Go Back   The Ranger Station Forums > Suspension & Armor > 4X4 Suspensions
Notices
4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks
Post New Thread Reply
Thread Tools Display Modes
Old 02-19-2008, 10:37 PM   #1
np205
np205's Avatar
Year: 95
Make: Ford
Model: F250
Engine: 7.3
Class: 4X4
Used For: Work and play
np205 is a jewel in the roughnp205 is a jewel in the roughnp205 is a jewel in the roughnp205 is a jewel in the rough
Default Shock valving
Looking at new front shocks and was looking at the Bilstein 5150's and wondered what valving to get for a ranger front end with 6" skyjacker springs. Their valving is 255/70 or 170/60? Any Ideas or just go with some pro-comp MX6's??? Thanks,
Owen
__________________
95 F250 Xtracab Powerstroke, 5 speed, 4X4, Stock for now
np205 is offline   Reply With Quote
Old 02-19-2008, 11:04 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
I put 255/70s on my BII, I figured they'd be stiffer than they are, but they're not overly soft. Unfortunately anything stiffer would need special ordering.
I've asked about MX6s in the past, the general consensus was they weren't anything special (the adjuster doesn't have much range, it's hard to tell all the way up from all the way down).
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 02-19-2008, 11:18 PM   #3
np205
np205's Avatar
Year: 95
Make: Ford
Model: F250
Engine: 7.3
Class: 4X4
Default
DO you think 2 would be needed per side in the front then for an xtra cab 4.0??? I have the duff coil buckets with dual shock mounts and thought if one good one per side would work I'd just go with that unless more is needed. But I also don't have jeep springs, just 6 in skyjacker ranger spring in the front.
__________________
Old 02-20-2008, 01:01 AM   #4
canyoncritter
canyoncritter's Avatar
Year: 1952,1991,1992
Make: Willys,Ford,Jee
Model: wagon,ranger 4x4,cheroke
canyoncritter is on a distinguished road
Default
just a thought, by the time you by double 5100 bills, you could come real close to the price of a 2.0 shock. and then you could vavle it as stiff as you like or as soft as you like.........
canyoncritter is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
