Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 07-07-2011, 01:34 PM   #1
DougInNJ
DougInNJ is on a distinguished road
Default R12 or 134a ?????
I have an '89 Ford Ranger. Hod can I tell if it has the original R12 or if it has been converted to 134a?
Thanks
DougInNJ
DougInNJ is offline   Reply With Quote
Old 07-07-2011, 01:38 PM   #2
exbass94
exbass94's Avatar
Year: 2006, 1994
Make: Ford
Model: Ranger, Explorer
Engine: 4.0 SOHC, 4.0 OHV
Class: 4x4
Used For: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Send a message via AIM to exbass94
Default
Usually when someone converts a vehicle to r134a, they put a sticker somewhere under the hood saying so. Usually it's on the radiator support. Also the service ports used for R-12 are a different size than R134a fittings. So if it has R134a, it should have adaptor fittings screwed on the service ports.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 45k miles
1994 Ford Explorer Sport 2-dr 4x4, 178k miles
exbass94 is offline   Reply With Quote
Old 07-07-2011, 01:39 PM   #3
sblake01
sblake01's Avatar
Year: 1990
Make: Ford
Model: Ranger XLT
Engine: 2.9
Class: 2WD
Used For: Daily Driver
sblake01 is on a distinguished road
Default
You might have to take it to an A/C shop that has a refrigerant identifier. If it was 'professionally' converted it would have R134a adapters on the high and low side ports and a tag somewhere under the hood.
EDIT: xbass94 types faster than I do
__________________
1990 Ranger XLT Supercab
(Purchased December 3, 2009 - Sold July 29, 2012)
Thanks for everything, TRS!
sblake01 is offline   Reply With Quote
Old 07-07-2011, 01:47 PM   #4
DougInNJ
Default
Thank you for responding, I'll check it out.
Man its hot here 94*!
Old 07-07-2011, 01:59 PM   #5
noahkenny
Year: 1989 1995
Make: Ford
Model: Ranger
Engine: 2.3l
noahkenny will become famous soon enough
Default
The service ports should be a dead give away if it has been converted. You can tell the difference just by looking at them. R12 fittings had threads on them where you screw on a set of gauges and the 134 fittings the gauges simply snap on to the service ports, no threads would be present on the externally. Only internally where the shrader vavle screws in. More than likely it had been converted. Been working on a/c systems for a long time and its been a few years since I actually seen a working r12 system. Not saying they arent still around but they are few and far between. I have an 89 model also that has converted about 10 years ago. If the hoses havent been changed to barrier lined (134a) hoses then you will lose 134a though the hoses as it permeates (goes through) the rubber. Really no big deal but it will lose somewhere in the neighbor hood of a can a year. Hopefully it has been converted. But even 134a prices have went up dramitcally over the last two years or so. Guarentee your evaporator coil will have a bunch of trash in it. Just remove the blower motor and the blower motor resistor and you can see up in there and dig that crap out. Then either blow it out or wash it out with water. Seeing that the truck is 22 years old cleaning the coil will help it dramitcally once you get the rest of the system in good working order. Not a bad idea to look between the condenser and the radiator to make sure its not packed up with a bunch of crap also over the years. Ever little bit help when it is this stinking hot.
noahkenny is offline   Reply With Quote
Old 07-07-2011, 03:34 PM   #6
DougInNJ
Default
Thank you NoahKenny
I'll check it out
Old 07-07-2011, 03:53 PM   #7
4.0B2
MALL CRAWLER POST WHORE!
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Used For: Taking my Money
4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute4.0B2 has a reputation beyond repute
Default
problem w/ that is-- it could be converted without leaving the adapters on the service ports. when i got that ranger i sold, it had r12 ports.. i checked it to see before i filled it and it was r134a in it. turns out the guy leaves the adapters w/ his gauges and doesn't leave them on the vehicles. his old 83 ford fullsize is the same way.
sad, but people do it. usually if its been converted, the ports are correct for the freon
4.0B2 is offline   Reply With Quote
Old 07-07-2011, 04:46 PM   #8
Heavyfire14
Heavyfire14's Avatar
Year: 1997
Make: FORD
Model: F150
Engine: 4.2l manual
Class: 2WD Off-Road
Used For: DD/Fun
Heavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the roughHeavyfire14 is a jewel in the rough
Default
yea, i had an 89 that was converted. it had the r12 ports and no sticker... you never know unless you take it in
__________________
Quote:
Originally Posted by nine-teen91stxranger View Post
duct tape and crazy glue. that holds anything together... duhh
Quote:
Originally Posted by 88_Eddie View Post
yeah it does. my wife and i have a 15th century battle axe suspended over our bed with it
2002 mazda b2300 ext. Cab 2.3l 5 speed
Build Thread
Heavyfire14 is offline   Reply With Quote
Old 07-07-2011, 04:49 PM   #9
Heavyfire14
Year: 1997
Make: FORD
Model: F150
Engine: 4.2l manual
Class: 2WD Off-Road
Used For: DD/Fun
Default
Quote:
hahahahaha i drive with my windows down at 94, man your lucky. its been 110-115 here lately and gets over 120* F. sometimes. haha and im usually outside all day
__________________
Build Thread
Old 07-07-2011, 04:51 PM   #10
noahkenny
Year: 1989 1995
Make: Ford
Model: Ranger
Engine: 2.3l
Default
I agree that does happen but if the conversion was done right it shouldnt be a problem. It takes someone stupid to take off the conversion fittings. A lot of them had loctite in them and would tear the threads off the orginal ports if you tried to remove them. Have run across it once or twice but as a whole its usually not a problem. The chances of a 22 year old truck still having r12 are pretty slim..
Old 07-07-2011, 05:19 PM   #11
4.0B2
4.0B2's Avatar
Year: 1988
Make: Ford
Model: Bronco II
Engine: 4.0 v6
Class: 4x4
Default
usually it would have leaked some by now, and needed freon. and surely people are converting it over instead of just refilling it w/ r12 (which is hard to find and stupid expensive)..
Old 07-07-2011, 05:30 PM   #12
Heavyfire14
Year: 1997
Make: FORD
Model: F150
Engine: 4.2l manual
Class: 2WD Off-Road
Used For: DD/Fun
Default
haha hopefully your not in cali. they tax the crap outta stuff like this
__________________
Build Thread
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
