- Dec 22, 2007
- Roanoke, VA
- Automatic
Have a problem with 88 F150 which has the 5.8L V8 engine vin H.
It idles around 900 rpm in park but when going into gear it will jump to around 1500-2000 rpm, but if I punch the gas it till start to stall out and backfire. I have removed the idle air control and cleaned with carb cleaner but did not seem to help out so I wonder if the throttle position sensor is bad? I scanned the codes and counted the flashes which were: 1111 then 13333 but can't make sense of that.
When in park if I punch the gas pedal it will hold around 2k rpm and will not drop back down till punching gas again which lead me to think it was throttle sensor. I have recently changed the plugs, plug wires, rotor button, and distributor cap. Had shop replace exhaust manifold to pass inspection and this idle is last thing I need to fix before ready to drive on road.
