| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| 4X4 Suspensions For stock & off-road suspensions using stock & aftermarket parts (IE suspension kits). Forum sponsored by RCI Metalworks |
Thread Tools | Display Modes |
#1 |
Junior Member
Year: 2003
Make: Ford
Model: SuperCab 4x4 4.0 Litre
Rep Power: 0 ![]() iTrader: (0)
I'm, wanting to do a suspension lift, approx. 3-4", I thought of using
Explorer 4x4 rear leaf spring assemblies with 2" blocks and turn up the torsion bars all the way up in the front? Is this doable and the most inexpensive route? I plan on putting 295-75Rx16 Nitto Terra Grapplers, they measure taller than the 305's and 315's, at 33.27x11.23x16. What do you think and do the tires hold up? |
Tweet
#2 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
You won't be able to crank the torsion bars up that high (and even if you could, you'd start blowing through CV joints and ball joints like no tomorrow).
I would get the BellTech Chevy shackles for it, turn up the torsion bars 2" (max) and get some 265/75R16 tires (285/75R16 if you're open to possibly having to modify the wheelwells slightly). Higher than that, you'll need an actual lift of some sort (body or suspension lift).
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
Tweet
#3 |
Junior Member
Year: 2003
Make: Ford
I already run 265.75RX16", with stock suspension and it has at least 2"
of clearance at the closest pt. the front fender corners, I heard if you do crank the TB's all the way up in decreases the life of your front end. what about cranking the TB's @ 2.5" and maybe coil over front shocks? I think the explorer 4x4 4dr. rear leaf springs with or without blocks will work on the rear? |
Tweet
#4 |
Mall-Rated
Year: 1990,1994
Make: Ford
Engine: 2.9L, 4.0L
2" over stock is really the max amount of lift height you want, regardless of how you do it.
The problem is the angle the balljoints and CV axle shafts will be at if you crank it up too high. You'll lose most of your suspension's downtravel as well. You could also add a body lift (that'll let you run those tires no problem). Beyond that, it gets much more costly (full suspension lift kit).
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
