| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 1994
Make: Ford
Model: Ranger XLT 4x4
Engine: 3.0 V6
Class: 4x4
Used For: Daily Driving~Light off-roading
Rep Power: 0 ![]() iTrader: (0)
i have a 94 3.0 w/approx. 128k miles. As of late after the truck warms up and reached operating temp. under load the coolant will collect in the overflow tank and begin to seep out of it. The coolant circulates normally through the system until it reaches temp and under load, then it just collects in the overflow tank and leaks out of the overflow tank hose gasket. I thought it might be the radiator cap, changed it and no difference. I also changed the t-stat too, no difference. I thought water pump but the coolant circulates through the system until it gets to temp and you drive it and it doesnt overheat. I've also flushed the coolant twice now too. The only other thing I can think of is headgasket? Any help would be appreciated.
__________________
1994 Ranger 3.0 XLT 4x4 ~ 2.5" exhaust ~ CAI ~ 8.8" L/S rear end swap |
Tweet
#2 | |
\----===FoMoCo===----/
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
Rep Power: 62 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
Quote:
Tweet
#4 | |
Year: 2002
Make: Ford
Model: Ranger FX-4 level 2
Engine: 4.0
Class: 4x4 Extreme
Used For: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Rep Power: 16 ![]() ![]() iTrader: (0)
Quote:
Most (if not all other) modern engines have DOORS that open and close to allow the heat to pass in the heater. The hot coolant flows thru the heater at all times. OUR rides have the old fashioned system that OPENS the flow of coolant into the heater when the heat is turned up. So when fillling the system with new coolant the flow MUST push all the air out of the heater!! Your problem sounds to me like a bunch of air in the system. Big JIm ![]()
Tweet
#5 |
Year: 1997 / 1989
Make: Ford
What I meant to say above was; Is it the correct rating on the radiator cap?
I got one once that was rated at a lower poundage than stock and it kept spilling over on me as yours is. (sorry about the above post, I was interrupted while typing and I'm not a good multi-tasker) |
Tweet
#6 |
If no air in system as BigJim suggests, then given what you've tried/inspected so far, possible fan clutch and/or just an old radiator that needs to be replaced. You might try using the heater full on to see if that makes a difference to coolant overflow.
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS, P235/70R-16, Synthetic fluids, Dual by-pass filter system, 60k |
Tweet
#7 |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Stock
Rep Power: 12 ![]() iTrader: (1)
How full is your overflow tank when it's cold? Are you sure it's actually "overflowing?" I had to put RTV on my elbow as it was not sealing against the tank and would leak when the coolant sloshed around in the tank.
You might also rent a cooling system pressure tester. If you had a blown head gasket it should show with that. |
Tweet
#8 |
Year: 1994
Make: Ford
Engine: 3.0 V6
Class: 4x4
Yes, did turn the heat on full blast when I filled the coolant. I don't think ( you know how that goes though) there is any air in the system, is there a reliable way to purge air from the system if so?
The radiator cap I bought is OEM replacement 16 lb cap (old cap i replaceled looked pretty beat) or at least that what is listed on the cap. I don't have the truck with me here at work at the moment. The overflow tank looks good. It's not actually "overflowing" from the tank. It's leaking out from around the rubber gasket that the plastic pickup elbow sits in at the top of the tank. The coolant level in the tank never gets high enough to actually breach the top of the tank. Does Autozone, or the like, rent cooling system pressure testers?
__________________
Tweet
#9 | |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0
Class: 2WD Stock
Quote:
Take a look at this thread: http://www.therangerstation.com/foru...ad.php?t=99703 In addition to that, like I said, I would rtv the entire thing down. After 15+ years the plastic wears out and isn't as tight fitting and the coolant gets out when it sloshes around in the tank. At a minimum it eliminates it as a point of failure. |
Tweet
#10 | |
Year: 1994
Make: Ford
Engine: 3.0 V6
Class: 4x4
Quote:
I did take the elbow out, no blockage, nor in the line that runs from the rad. to the overflow tank. Should I RTV the actual rubber gasket itself or pull it out and the sides of it? I'll also try cutting the hose back and re-clamping it like suggested in the linked thread. I'll also do the pressure test too, just to see.
__________________
Tweet
#11 |
Year: 1994
Make: Ford
Engine: 3.0 V6
Class: 4x4
Finally got the pressure tester. Did the test stayed at a rock solid 16ish psi. I pumped the gauge until the needle was on the 16 side of the 15-16 psi area. It said to leave it on for 2 min, it was prolly on for a good 30-40 min or so as I checked for leaks, it held firm on the 16 the whole time.
I did notice one small leak right at the bottom (trans cooler line?) fitting. The bottom fitting (closest to the ground) on the driver side of the radiator (second fitting down from the filler neck) the line that runs from the small transmission cooling radiator. There is a small leak coming from the area of that fitting, I have never noticed it before. Would be enough to cause my problem?
__________________
Tweet
#12 |
Year: 1999
Make: Ford
Model: XLT
Engine: V-6 3.0
Used For: Every day driving
Ok I had this same exact problem and after replacing almost everything under the hood (as far as the coolant system goes) I broke it down and took the head gaskets off to find out the one on the left bank had a nice pin size hole in it. Atleast thats how my mileage varied lol. So now I discovered my truck leaking oil from the heads and I can get them to stop. Any advice on that one?
Tweet
| Bookmarks |
| Tags |
| coolant problem, headgasket |
| Thread Tools | |
| Display Modes | |
