Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 06-11-2011, 09:03 AM   #1
The Dog's Truck
The Dog's Truck's Avatar
Year: '91
Make: Ford Ranger
Model: Ranger XLT
The Dog's Truck is on a distinguished road
Talking Just bought an Interesting Ranger...
We just picked up this Ranger locally for $700.
the very nice lady we bought it from said here son had bought it new back in 91 and took good care of it. She told us it was 4wd but just a little 4cyl and starting to showing its age a bit.
so with out seeing any pictures we went down to look at it...
I dont know much about Rangers, but i know a good deal when i see one.
I would love to know anything you guys can tell me about this little ranger.
Obviously its a v6 now. Any info on what motor would be good, it has braided steel fuel lines and enough hacked wire connectors to make me think this was not its original home.
and then there is the suspension.
its also got shock hoops and 2.5 inch body spacers. the tires on it are 31's we were given two sets of wheels and tires for it. what ever gearing it has right now is fine for those tires, maybe even a little short.
I have spent most of my time wrenching on jeeps. Jackie, the other owner of this truck, has had her self a few escorts, including one thats down to 11.06 on a cosworth motor. But still new to the truck side of ford.
The nice Lady we bought it from claims it does pretty well in the snow.
The Dog's Truck is offline   Reply With Quote
Old 06-11-2011, 09:19 AM   #2
MountainMike
MountainMike's Avatar
Year: 1993
Make: Ford
Model: Ranger Interceptor
Engine: 245 CID
Class: 4x4 Off-Road
Used For: Truck Stuff
MountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to beholdMountainMike is a splendid one to behold
Default
That's a nice looking little rig you picked up
__________________
1993 4x4 project: FX4 Level III <-Click
4.0L, A4LD, 3.27's, 2" Washer lift, Sway bar pins, Flexy rear leaves, Rancho shocks, Belltech 6400's, 3" BL, 32" Goodyear Wrangler MTR-K's
Quote:
Originally Posted by disciplerocks View Post
Ranger Interceptor at work.
Quote:
Originally Posted by JohnnyO View Post
WWTRSD?
MountainMike is offline   Reply With Quote
Old 06-11-2011, 09:53 AM   #3
97fordrunner
97fordrunner's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Weekend Wheeler
97fordrunner will become famous soon enough
Default
Looks to me like a 4.0 V6, Can tell by the coil pack. 2.5-3" James Duff Suspension lift which is one of the better available for rangers. The Trans looks to be a M5OD 5spd which is a great transmission. I'd say you got a pretty good deal on it. the spliced wires and be fixed with a complete underhood wiring harness that you should be able to find from a junk yard. Just search for 91-92 ranger with a 4.0 and manual. Also it looks like it has a Dana 35 and 8.8 axles in it which would not have come in a 4cyl so those were either swapped or it is originally a 4.0 truck. You could check the VIN. If those are stock axles probably looking at 3.55 gears which are just dandy with 31s and a 5spd. There should be a tag on the rear axle bolted to the diff cover should see 3 55 or 3 73 or possibly a 3L55 which would suggest a Limited slip but not real common in that era truck.
Any plans for it or just to mess around with?
__________________
'97 Ranger 4.0, Auto 5" custom Suspension 3" Body lift. 35" Baja Claws, 4.88 gears Rear locked. Warn jeep Hubs.
Build Thread
"since we didn't know what to do, we sat down and did nothing" - James May, Top Gear BBC
Ranger Militia Member
97fordrunner is offline   Reply With Quote
Old 06-11-2011, 10:10 AM   #4
The Dog's Truck
Year: '91
Make: Ford Ranger
Model: Ranger XLT
Default
i like what i am hearing so far.
What am I looking for on the coil packs to confirm 4.0 status. I will be redoing the under hood wiring myself. engine swap harnesses and troubleshooting is my weekend job.
As for build plans, we are starting with rust repair and are probably taking the cab off to coat the frame and under side with implement paint.
after that I am looking to stick bigger tires under it to get the diff a bit higher off the ground and get some better flex out of the front end.
I promised to stop short of changing out the axles on this one. so what ever i can get away with up untill that point i guess. it needs to remain a road going truck and we will be taking it out to the midwest this fall. so everything is with that in mind.
Old 06-11-2011, 10:15 AM   #5
shane96ranger
\----===FoMoCo===----/
shane96ranger's Avatar
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
shane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond reputeshane96ranger has a reputation beyond repute
Default
It's a 4.0, I can tell by looking at it. Your vin code should be X for the 4.0 if you want to confirm.
I think the orange sticker on the coil pack says 4.0 on it IIRC.
__________________
Click to see my 97 F-150 XLT
Click to see my 89 Mustang GT
Quote:
Originally Posted by jammert609@yahoo.com View Post
I am being told by family an friends my truck is a piece of shit
shane96ranger is offline   Reply With Quote
Old 06-11-2011, 10:52 AM   #6
RangerMtnHigh
Year: 2008
Make: Ford
Model: Ranger Sport 4x4
Engine: 3.slow
Class: 4x4
Used For: driving
RangerMtnHigh is on a distinguished road
Default
sweet deal
RangerMtnHigh is offline   Reply With Quote
Old 06-11-2011, 10:56 AM   #7
racsan
racsan's Avatar
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
racsan has a spectacular aura aboutracsan has a spectacular aura aboutracsan has a spectacular aura about
Send a message via ICQ to racsan Send a message via AIM to racsan Send a message via Yahoo to racsan
Default
engine looks like my 4.0, the coil pack, intake and oil fill cap. good deal.
__________________
at the corner of "walk" & "dont walk" cardomain link:--> http://www.cardomain.com/ride/3216869 1993 ranger s/c 4.0 hurst-equipped 5-spd,3.73s ,4x4, milemarker hubs, black grille guard/tube steps,summit rear diff cover with bearing load supports. 117K & still going strong. http://www.myspace.com/small_dog_trucking
racsan is offline   Reply With Quote
Old 06-11-2011, 06:45 PM   #8
trail B2
trail B2's Avatar
Year: 1986
Make: ford
Model: bronco 2
Engine: 4.0
Class: 4x4
Used For: 4x4 and DD
trail B2 will become famous soon enough
Default
It has pretty good axles in it now.Your right you can spot a good deal.
__________________
We make A living by what we get, We make A life by what we give.http://www.therangerstation.com/foru...lies/yahoo.gif
trail B2 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
