| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2006, 1994
Make: Ford
Model: Ranger, Explorer
Engine: 4.0 SOHC, 4.0 OHV
Class: 4x4
Used For: Pavement Poundin'
Rep Power: 21 ![]() ![]() ![]() ![]() iTrader: (0)
The ABS light on the Explorer won't turn off. This all started a few weeks ago when my A/C kept blowing the fuse. After some troubleshooting, I determined it was the A/C WOT relay. To confirm this, I swapped one of the ABS relays with the A/C relay. Sure enough, the A/C has not blown a fuse since, but the ABS light went on. So I bought a new relay and installed it in the ABS slot. The light stayed out for about a day, but then came back on. I checked all the fuses and they're ok. The light will turn on for a few seconds when I first start the truck, like it should. It stays off until I start driving. Within the first few seconds of moving, it turns on and stays on.
Since the light stays out until the truck starts moving, I'm thinking it might just be a sensor and that it just coincidentally happened after this relay fiasco. Is there a way to check ABS codes with an OBD1 system?
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 46k miles 1994 Ford Explorer Sport 2-dr 4x4, 179k miles |
Tweet
#2 |
\----===FoMoCo===----/
Year: 1997 / 1989
Make: Ford
Model: F150 XLT / Mustang GT
Engine: 4.6 Triton / 5.0
Class: 4X4 / Hot Rod
Used For: Everything / The war on imports
Rep Power: 64 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
Is your brake fluid reservoir full?
Tweet
#3 |
Year: 2006, 1994
Make: Ford
Class: 4x4
Yup it's full.
__________________
Tweet
#4 |
Year: 2006, 1994
Make: Ford
Class: 4x4
I guess I should add that the parking brake light works correctly, and it's JUST the ABS light that won't turn off.
__________________
Tweet
#5 |
Year: 1994/2004
Make: Ford
Model: Ranger XL/F250 XL
Engine: 2.3L/5.4L
Class: 4x4
Used For: DD and Mild Wheeling
Rep Power: 15 ![]() ![]() iTrader: (2)
I had this problem with my Ranger. Under the master cylinder mounted on the frame rail is the RABS control module. I found that I had been dripping oil on this connector during oil changes and I had opened a connection. I pulled the plug out, hit both connectors with an electrical contact cleaner and let the dry. Neatened them up with electrical tape afterwards to add a bit of extra protection. Don't forget to disconnect the positive battery terminal before doing this! Hope it helps!
__________________
"Light beer is just wasting your time..." -My grandmaProject Little Green Turd F250 Build |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
