- Aug 9, 2007
- Automatic
Baddad, when doing a 302 w/AOD swap what is the correct position for the "C" shaped lever that goes to the TV cable? And, do you have to install the new Lokar lever relocation kit if the OE lever on the tranny is already in the top position? The 302 and tranny are out of a '88 Crown Vic, the trans was set-up with a column shift and now I have it with a Mustang floor shift.
