Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 05-03-2011, 05:31 PM   #1
cthudak
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 4X4
cthudak is on a distinguished road
Default Cam shaft synchronizer
Hi everyone,
Can someone tell me a definite way to determine which length Cam Synchronizer I need for my 1997 4.0 Ranger? Motorcraft, NAPA and Rock Auto both offer the 123MM and the 132mm length part. Being that this part is in a bad spot, I would like to be 100% sure of the part I buy before I start disassembly.
Thanks for the great site and for the help.
cthudak is offline   Reply With Quote
Old 05-03-2011, 06:17 PM   #2
Bray D
2012 UA Ranger
Bray D's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 Extreme
Used For: DD/Weekend Warrior
Bray D will become famous soon enoughBray D will become famous soon enough
Default
I hopped on napaonline.com and searched it just for kicks. That's really weird. Have you talked to anyone in person about the issue? I'd stop by a ford dealership and see what they offer as the OEM replacement.
__________________
'96 ranger - narrowed HP D44, ChroMo shafts, geared/locked, hi-steer - 31 spline 8.8, dutchman shafts -1350/1354 doubler - 37's on TR beadlocks. Driven daily.
Bray D is offline   Reply With Quote
Old 05-03-2011, 06:56 PM   #3
brinker88
Premium Member
brinker88's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: Weekend Warrior
brinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to beholdbrinker88 is a splendid one to behold
Default
Do you defintely have a SOHC? I though most '97s had the OHV? The OHV ones dont really have a problem, its the SOHC electonic ones.
http://www.fordrangerforum.com/3-0-v...now-needs.html
brinker88 is offline   Reply With Quote
Old 05-03-2011, 07:03 PM   #4
cthudak
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 4X4
Default
Its an OHV 4.0 ....using a stethoscope, the squeek is definitly coming from the cam synch / sensor ( can barely see it)
Old 05-03-2011, 07:05 PM   #5
brinker88
Premium Member
brinker88's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Well I called ford about 3 months ago and they do not carry it anymore. Your ONLY option is a junkyard or the internet
Old 05-03-2011, 07:23 PM   #6
Bray D
2012 UA Ranger
Bray D's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 Extreme
Default
Yeah, I know what you're sayin. I guess if its over 10yrs old they discontinue it. Ripoff. They may still be able to get it though, if another parts department still has one on the shelf.
They should be able to tell you which one it is even if they can't get one. Maybe not?
__________________
Old 05-03-2011, 07:41 PM   #7
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
I can tell you that both my 95 and my 96 had the 123mm. The 2000 I bought had a 132mm.
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,....
4BT swap thread
Ranger bed trailer build
Scars are just tattoos... with better stories!
snoranger is offline   Reply With Quote
Old 05-03-2011, 07:51 PM   #8
Bray D
2012 UA Ranger
Bray D's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4 Extreme
Default
I guess you could just pull the synchro and measure it? I know its a PITA, but at least you'd know for sure. Sucks spending money on something to find out its not what you need.
__________________
Old 05-07-2011, 02:59 AM   #9
Snurfer
Snurfer's Avatar
Year: 1995
Make: Ford
Model: Ranger 4.0 SUPERCHARGED
Snurfer is on a distinguished road
Default
your ranger being a 97 will have the two piece cam sychro/sensor design. it should have the black sensor housing with two bolts securing it to the top of the synchro shaft. this is the longer version of the synchronizer. the shorter version of the synhro assembly came in the earlier trucks with 95 being the last year i believe. it uses an integrated one piece sensor/ shaft design.
__________________
95 ranger SC SUPERCHARGED 4.0.
SAS. Belltech/ 4in ex. leafs rear.
01 ohc w/ temp. 05 sporttrac leather buckets w/ heat
02 taillights/ sporttrac instruments
35x13.50r15 toyo MTs/ 4.56 locked F/R
Snurfer is offline   Reply With Quote
Old 05-07-2011, 10:34 AM   #10
brinker88
Premium Member
brinker88's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Good info dude thanks!
__________________
Obsession is a word justifying your insanity. We ARE the 4x4%.
Build Thread
Old 05-07-2011, 12:01 PM   #11
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Class: none
Default
I have 4 cam syncs on my desk at work. (I have these because I'm machining a custom cam sync for my SOHC EEC-IV swap) Heres what I found:
-They all use the same outer housing. (same part number on the casting, from 95-2000 maybe more)
-The gears are in the same location on either length.
-The extra 9mm is just an extension at the bottom of the shaft where the oil pump drive goes.
-The extra 9mm is smaller outer diameter then the part of the shaft that locates it in the block (and the gear presses onto).
-The SOHC (oil pump drive only, never came with a cam sync) did away with the extra 9mm. (checked both 97 and 01 SOHC)
Not that this really helps you with your question, but I figured it may help someone else if they figure out how to use the search button!
__________________
4BT swap thread
Old 05-07-2011, 12:29 PM   #12
brinker88
Premium Member
brinker88's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
OHV though...what about them...I've never really heard they go bad very often
__________________
Build Thread
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
