Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-05-2011, 04:44 PM   #1
Dave93XLT
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0L V6
Class: 2WD Street
Dave93XLT is on a distinguished road
Default No power from my 3.0
Here's the low down:
1993 XLT w/2009 Ford rebuilt 3.0L V6 short block.
5 speed OD manual tranny (original)
K&N cold air intake.
Underdog pulleys.
Electric fan.
MSD coil, new plugs, wires, cap and rotor.
You would think this motor would have some power, wrong. It runs fine as long as I am on a flat surface or going downhill. Once I start uphill, it's like there is no torque at all. Even when I mash the accelerator to the floor there's no power, just the sound of more gas burning.
I'm not sure if it is a compression issue, vacuum issue, PCM issue or what. I've thought about adding a Jet module to see if that would help, but wanted to check with you guys before I did to see if maybe someone else experienced this same problem and had some advice.
Let the threads begin.
Dave93XLT
Dave93XLT is offline   Reply With Quote
Old 04-05-2011, 04:50 PM   #2
RavoHimself
RavoHimself's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD
RavoHimself will become famous soon enoughRavoHimself will become famous soon enough
Default
have you tried downshifting.
__________________
93 ranger, 4.0L, ex cab, standard, 4x4, 2" coils, 15x8 AR Baja, 33x10.5" bfg at, cab lights
Build Thread
........to be modified........
-Ryan-
RavoHimself is offline   Reply With Quote
Old 04-05-2011, 05:03 PM   #3
Dave93XLT
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0L V6
Class: 2WD Street
Default
Yep. But it doesn't seem like I should have too even on the smallest of inclines.
Old 04-05-2011, 06:01 PM   #4
Big Jim M
Year: 2002
Make: Ford
Model: Ranger FX-4 level 2
Engine: 4.0
Class: 4x4 Extreme
Used For: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Wink Ha!
Underdog pulleys.
Electric fan.
Dave93XLT
I wouldn't think ANY of the things you have bolted on there would give you one bit more power.. Seems to me you are one of the only guys that has went to all that trouble and TELLS THE TRUTH!
Just for grins and giggles tell us what gear ratio you have and what size tires you are running..
Big JIm
Big Jim M is offline   Reply With Quote
Old 04-05-2011, 06:05 PM   #5
clifford97
clifford97's Avatar
Year: 1997
Make: ford
Model: ranger- (not a danger ranger!)
Engine: 3.0
Class: 4x4
Used For: DD, fun!
clifford97 will become famous soon enough
Default
its cuz u have a 3.0 thats y mine is a big red dog
__________________
just my $.02
"I knew you were going to get stuck. you thought u were in your ranger, you forgot you were in a jeep"
clifford97 is offline   Reply With Quote
Old 04-05-2011, 06:24 PM   #6
Dave93XLT
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 3.0L V6
Class: 2WD Street
Default
Stock gears with 15 inch wheels. Nothing extreme.
Old 04-05-2011, 07:07 PM   #7
RollinWOT
RollinWOT's Avatar
Year: 1998/2000
Make: Ford/Saturn
Model: Ranger/SL2 "SL-Deuce"
Engine: 3.0L Vulcan/1.9L DOHC
Class: Mild 2WD Off Road
Used For: Causing Trouble/Commuting
RollinWOT will become famous soon enough
Default
Yep, I've got a 3L too. Auto, but still. No power is the norm.
__________________
MBRP Off-Road Pro Cat-Back Shorty Exhaust/ Westin Side Deflectors/ Offroad Bumper in the works/ Powertrax Lock-Rite install soon/ Bullet Holes(and lots of 'em)
THIN BLUE LINE PLATE
RollinWOT is offline   Reply With Quote
Old 04-05-2011, 07:41 PM   #8
stmitch
March 2011 STOTM Winner
stmitch's Avatar
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2wd street
Used For: Looking good. Soon to be going fast!
stmitch will become famous soon enoughstmitch will become famous soon enough
Default
I think a little more info would help, before jumping to any conclusions.
Do you know what your gear ratio is? What size tires are you running? Properly sizing your gear ratio can make a huge difference in how the truck moves.
Is this a new problem, or has it been this way since you put the new motor in?
stmitch is offline   Reply With Quote
Old 04-05-2011, 08:05 PM   #9
Froggmann
Froggmann's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Ex. Cab
Engine: 3.0FFV
Class: 4x4
Froggmann will become famous soon enough
Default
Pull codes.
__________________
5spd, 3.73's, 245/75-16's, Tinted Windows, Exp OHC, U/D Crank Pulley, Composite Upper Intake/Half shafted 05' TB, E-Fan, Air box Mod, CC's, 06 Tail Lights, Lowered 2.5" Rear/2" FR, Sound Deadened.
Froggmann is offline   Reply With Quote
Old 04-05-2011, 08:23 PM   #10
trail B2
trail B2's Avatar
Year: 1986
Make: ford
Model: bronco 2
Engine: 4.0
Class: 4x4
Used For: 4x4 and DD
trail B2 will become famous soon enough
Default
A 2.9 is the same thing is it broken or real slow that is the question.It's real hard to tell from here.Hopefully someone who solved 3.0 power problems can come up with some thing you haven't thought of.
__________________
We make A living by what we get, We make A life by what we give.http://www.therangerstation.com/foru...lies/yahoo.gif
trail B2 is offline   Reply With Quote
Old 04-05-2011, 08:29 PM   #11
Rearanger
Year: 2003
Make: Ford
Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
Quote:
Resisting the urge to poke fun at the no power mods, stmitch is right. How long have you had the add-ons and were you getting better power just before/after you installed them? Were the mods an attempt to solve what you perceived as "no power"? Have you done a compression test? Could the clutch be slipping? You need to look a little closer. You could also test drive an 09 (same engine) and see if it feels better than yours.
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, Dual by-pass filter system, 60k
Rearanger is offline   Reply With Quote
Old 04-05-2011, 08:45 PM   #12
stiluv
Premium Member
stiluv's Avatar
Year: 1999
Make: ford
Model: ranger
Engine: 5.oh face oh oh oh
Class: 4x4
Used For: picking up your mom, taking her out and never calling her again
stiluv is on a distinguished road
Default
3L are high reving motors use the rpm's.they will go all day at 5-6 grand. there is not much you can do for power. i have a 99 with a 3L and it does ok. 4.88 gears with 33's. oh ya and when i did the head gaskets i did a little porting of the heads and intake. it help a good bit.
stiluv is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
