front end clicking noise
jessezipper
10+ Year Member
livonia
im not sure where to post this so ill start here. i finally got my ranger on the road, while driving down my street, ive noticed a clicking type noise. when i push the clutch in, it goes away and while in reverse theres no clicking. what could it be?? the truck was in 2wd. i have yet to try it in 4wd..
Need more info about the truck itself. Please fill that out in your profile so that we don't have to ask to help.
I was gonna say a ujoint till u say it goes away when u put the clutch in. Hmm maybe someone else has a idea.
yea i thought it was a u joint i put the clutch in while cruising n the noise went away , it shifts fine , tcase shifts fine in and out of 4wd.
I'd guess it's something in the clutch. Bad throw out bearing maybe. Does it do it in all gears?
havent gone past second gear, it does it in first n second, not in reverse tho..
I had a pilot bearing (?) end of crank & front transmission shaft bearing break into pieces. One of them fell into the clutch & rattled around. When I put the clutch in, the pressure plate would bind up the piece & the rattle stopped. It's a longshot, but if all else fails....
i bought it last fall, before i bought it , it sat for 5 yrs, so i think ima replace all the clutch stuff , if i gotta do a bearing anyways..
took it for a drive today, went through all the gears, it clicks in all the gears, i put it in neutral or the clutch is in , no noise. i can feel it in the shifter. it almost sounds and feels like gears arent meshed right, if thats possible. gonna drain and refill the fluid this weekend.
