Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 03-20-2011, 09:44 AM   #1
whocares
whocares is on a distinguished road
Default Advice on fixing this, please.
I have an 89bII with the stock 7.5, ls, 3.73. I was under the truck today checking my u-joints and noticed the rear pinion has some movement to it when I move the driveshaft up and down.
Its quiet on the road, no whine, leaks or noise at all from the rearend, is it possible I can get away with just tightening it or am I looking at something more involved?
__________________
89 BII, a work in progress.
whocares is offline   Reply With Quote
Old 03-20-2011, 05:53 PM   #2
4x4junkie
Mall-Rated
4x4junkie's Avatar
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all4x4junkie is a name known to all
Default
You can try retightening it to around 120ft-lbs or so (don't go more than this though, or you'll likely be replacing the crush sleeve), though simply not being noisy isn't a guarantee there's a bigger issue. Do put a very tiny tack-weld on the nut after you do tighten it though so it can't loosen up again (alternatively you could remove the nut entirely, clean all the oil off the threads with some no-residue spray cleaner, and reinstall the nut using Loctite threadlocker).
Be sure to check that the pinion bearing preload torque is within specs after you tighten it (you'll need to remove the diff carrier to do this correctly). Specs can be found here. If it feels rough at all, chances are good the pinion bearings are hosed.
__________________
'90 Bronco II XLT
5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s
'94 Ranger XLT
6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s
4x4junkie is offline   Reply With Quote
Old 03-20-2011, 06:05 PM   #3
whocares
Default
I appreciate the advice. I'm hoping I can tighten it and it will last until I run across the right deal on a 8.8, I really dont want to spend the money and time on fixing the 7.5.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
