| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress. |
Thread Tools | Display Modes |
#1 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Weekend Wheeler
Rep Power: 13 ![]() iTrader: (6)
Thought I should start a build thread on my truck now that I have started modding it for some serious trail running.
As it sits now it has a rough country 4" lift that is soon to be a custom lift with custom drop brackets, Skyjacker Radius Arms, EB coils, Stone Crusher steering, F250 shock towers and Bilstein 5150 shocks. Over the weekend I rounded up a buddy that works at a drive line shop rebuilding transmissions and diffs and had him give me a hand with installing my Yukon 4.88's ![]() Also have a No-Slip that I was gonna get installed but I ordered the wrong spring kits And I also installed new Spicer U-Joints and C-clip eliminator spring. Up in the air ![]() 3.73 Limited Slip ![]() Open Carrier with 4.88 gear ![]() Drilled a small hole the front diff to drain oil through bottom bold hole (Got that Idea from 4X4Junkie) ![]() Axles ![]() C-Clip eliminator ![]() Drilled out front Yoke and installed U-Bolt straps # 534-10 ![]() Soon to be installed No-Slip ![]() More to come soon
__________________
'97 Ranger 4.0, Auto 5" custom Suspension 3" Body lift. 35" Baja Claws, 4.88 gears Rear locked. Warn jeep Hubs. Build Thread "since we didn't know what to do, we sat down and did nothing" - James May, Top Gear BBC Ranger Militia Member
Tweet
#2 |
December 2011 OTOTM Winner
Year: 1996
Make: Ford
Model: Ranger SC 4X4
Engine: 4.0
Class: 4x4 Extreme
Used For: everything
Rep Power: 15 ![]() ![]() iTrader: (2)
nice start....you will like the front locker.....
l8r, John
__________________
SAS with leaves, KP HP D60 front, D60 FF rear, 4.88's, 39.5x13.50x17" Bias Iroks, 17" Allied Beadlocks, winch, and a few dents and scratches...... |
Tweet
#3 |
Year: 2006
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: DD/Gold Prospecting
Rep Power: 19 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Looking good man! 97' is the perfect year for a build in my opinion. I wish I had that 4.0/M5OD combo. What size tires do you plan to run, and how much did the radius arms run you? Do you have the part number on the u-bolt straps?
__________________
1987 Ranger, D35 swap, sploder 8.8 Build thread>> http://therangerstation.com/forums/s...ad.php?t=97183 (sold) 1997 F150 Lariat 4x4:RIP 2006 Ranger 4.0, 4x4, all stock... for the time being |
Tweet
#4 | |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Quote:
Railman the locker is for the 8.8 I am thinking an ARB in the future after all else is done
__________________
Tweet
#5 |
Year: 2006
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Sweet! Thanks man.
__________________
Tweet
#6 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Well not a lot of progress other than the addition of the Baja Claws
![]() I did however order up my replacement rear leaf hangers, New DPFE sensor to replace the corroded aluminum one. Also got the spring kit I needed to install the no-slip and have a Stone Crusher Steering set up coming from Anthony. What a guy he is a real cool guy and real easy to deal with. Can't wait for it to get here and do the install
__________________
Tweet
#7 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
So Finally getting a few things done on the truck after a long break with a back injury. Got the No-Slip installed yesterday and also got the Stonecrusher Steering installed and then got to try out the tires, and locker out back of work in a slimy hole that my boss was rutting around in with his skid steer. No Problems with traction anymore! Also removed the 14 oz of stick on wheel weights that were on the tires and threw a 6oz bag in each tire so that should help
Here is a pic of the steering. And I will try and get some more pics of progress ![]() Next up is re-doing the suspension and replace the rear hangers and shackles
__________________
Tweet
#8 | |
Motorboater (.Y.)
Year: 1988, 2000
Make: Ford
Model: Bronco II (Eddie Bauer), Explorer
Engine: 2.9L, 4.0L
Class: 4x4, 2WD
Used For: Annoying the old ball and chain.
Rep Power: 48 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (6)
how does the stonecrusher drive?
i like the build
__________________
BUILD THREAD<<<<<<<<<<<<< The Tikki Torch Build Thread 1988 Bronco II 4x4 2.9, FM146, 1350M, Disc 8.8, D30 SAS, 3.73's, 31's (for now) 2000 Explorer 4.0 2WD DD Everything I need to know about Islam, I learned on 9/11. The hardest part about a zombie apocalypse will be pretending I'm not excited. Quote:
Tweet
#9 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Haven't put to many miles on it but great so far. Much better than worn out TRE's for sure.
__________________
Tweet
#10 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Something missing, Can't put my finger on it
![]() Gonna pull the bumper and receiver tomorrow and then hopefully get the Belltechs and new hangers on this weekend. Or i'm gonna finally tackle to front suspension but I know the rear is about to fall off the frame. Thats why I removed the box but I may try and sell it while its off to fund a bed cage build
__________________
Tweet
#11 |
Year: 1996
Make: Ford
Engine: 4.0
Class: 4x4 Extreme
if ya have tight trails like we do here....you will like the tube bed
looks really good so far..... l8r, John
__________________
Tweet
#12 |
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3l of fury
Class: 2WD
Used For: DD and mall crawlinz
Rep Power: 15 ![]() ![]() ![]() ![]() iTrader: (1)
Limited slip? Lucky you. I envy you.
__________________
1995 XLT 2wd, 2.3, M5OD-R1 1993 XLT 2wd, 4.0, M5OD-R1 1991 XLT 4wd, 2.9, FM146 See my build thread
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
