I've been looking around for a trans for the ranger and came across this. The guy says he's parting out the whole truck due to a bad starter (sounds a bit fishy) and is selling the M5OD for only $150 which seems a bit low even with 130k on the odometer (a little more fishy) and "just replaced fluid" in it (pretty fishy [can't check the fluid to see if the trans has eaten itself apart]). What do y'all think? What would be the best way to go about seeing if the trans is good or not? I know I can check the seals at the top of the trans to see if they've been leaking, check the fluid for bits of eaten transmission even though it was recently changed out I'd think there would still be some bits in there if the trans was fried. Let me know what you guys think. http://seattle.craigslist.org/est/pts/2239580057.html
