Go Back   The Ranger Station Forums > Engine & Transmission Forums > Transmissions
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 02-21-2011, 05:27 PM   #1
jimmy1979
Junior Member
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.OL
Class: 4x4
Used For: Getting to your sister's house.
jimmy1979 is on a distinguished road
Default Clutch movement
If I look into the opening on the bottom of my transmission(91 ext cab, 4x4, 5 speed, 4.0) while someone is pushing the clutch pedal, I should be able to see some movement in there right?
jimmy1979 is offline   Reply With Quote
Old 02-24-2011, 08:10 AM   #2
jimmy1979
Junior Member
Year: 1991
Make: Ford
Model: Ranger
Engine: 4.OL
Class: 4x4
Default
Had to remove the master and bench bleed it, then did the gravity feed with everything installed. Now I can see things moving.
Is there supposed to be a cover or plug on that inspection hole? It seems kinda odd that the clutch would be left open like that.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
