#1 |
Junior Member
Rep Power: 12 ![]() |
On my wife's '04 F150 whenever the truck is put into reverse the back up alarm shuts itself off. I unplugged/replugged in all sensors and checked the #18 fuse but everything seems ok. Anybody else have this problem or know where I should look next?
__________________
'92 Explorer Sport, 5-speed, swapped in manual t-case, 4.88s and Ecteds, on-board shower, Co2, Duff 5.5" lift with stock SOA in the rear, coming into its own. |
#2 |
Rep Power: 8 ![]() |
Pretty common. Probably a bad sensor but you really need a scan tool to tell you which sensor is bad. Not sure if any aftermarket scanners can check it but the Ford IDS will let you monitor the sensors.
#3 |
Junior Member
Thanks, thats kind of what I thought. The truck is booked in tomorrow for a factory service anyways, I just hoped there was something obvious or simple I could try before paying them to look at it.
__________________
| Bookmarks |
| Thread Tools | |
| Display Modes | |
