| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#1 |
Year: 2001
Make: Ford
Model: Ranger 3.slooow
Class: 2wd
Used For: DD
Rep Power: 9 ![]() iTrader: (0)
I've been trying to locate a coolant leak which I have found but I am unsure which of the 2 in this photo is the coolant temp sensor.. I believe it's the one on the left with a red connector and if so is the one on the right the temp reader for my dash gauge ? I'm confused.. Thanks..
Here is a picture of the leak itself in action right under where the red connector is and i can't unscrew it because the hose fitting at the bottom hits the bracket where my tension pulley is.. wa wa wa...
Tweet
#3 |
Year: 1983
Make: ford
Model: ranger
Engine: 2.8l
Class: 2WD street
Used For: DD tow boat
Rep Power: 19 ![]() ![]() ![]() ![]() iTrader: (0)
normally one wire is the sender for the guage or light and the two wire is for the computer.
__________________
it takes a nickle to go first class when it stops hurting it will feel alot better
Tweet
#4 |
Year: 1999
Make: Ford
Model: Ranger Ext Cab 4X4
Engine: 3.0
Class: 4x4
Used For: daily driver
Rep Power: 0 ![]() iTrader: (0)
its the one with two wires cts have all had two wires since like 1982
__________________
How stuck can you get?
Tweet
#5 |
Year: 2001
Make: Ford
Class: 2wd
Used For: DD
In that case it looks like the one on the right has 2 wires but the one on the left looks like it has a red and white but id have to look again. If the one on the left is just the gauge reader I'm thinking the leak right below it could be the cause.. The hose beneath that sensor hooked to that fitting runs down and joins into my lower radiator hose.
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
