| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Need Urgent Help Fast! |
Thread Tools | Display Modes |
#1 |
Junior Member
Ok, so i removed my cylinder heads, and now i have the engine all back together. I heard something about setting the valve lash? I have the 2.9L V-6. I just unbolted the rockers and springs as a whole assembaly, and re-installed them the same, and i made sure to install the pushrods in the same locations i pulled them from. Do I need to set the valve lash? what will happen if not? I thought the valve lash only needed to be adjusted if you remove the valve springs individually or replace the rods or something? Any input?
Tweet
#2 |
Year: 1990,1989
Make: Ford
Model: B2,ranger
Engine: 2.9, 4.0, 5.0 can't decide
Class: 4x4,2wd street
Used For: wasting garage space
Rep Power: 12 ![]() ![]() ![]() iTrader: (0)
the lifters are hydrolic so as long as you have moved the internals it should pick up the slack on its own
__________________
wtb: dana 35 ttb 4:10 gears |
Tweet
#3 |
Premium Member
Year: 1984, 1999
Make: Ford
Model: Ranger
Engine: 2.8L, 3.0L
Class: 4x4's
Used For: Project, DD
Rep Power: 23 ![]() ![]() ![]() iTrader: (2)
Yep only the 2.8L has adjustable valves vs hydrolic ones
__________________
99 Ranger DD - 3.0L, 5spd, 4x4, 4 door, step side, 31's, 4x KC driving lights. 84 Ranger Project - 2.8L, 5spd, 4x4, regular cab, long bed, 3" body lift, 31's, 4x KC long ranges, Dual CD player/Blaupunkt Speakers. |
Tweet
#4 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Used For: Daily driver. Fishing vehicle. Use from time to time to run down crack heads.
Rep Power: 13 ![]() ![]() ![]() iTrader: (0)
There is actually a way to adjust valve lash on the 2.9L too though.
Tweet
#5 |
Year: 1979/93
Make: Ford
Model: f250/ranger super
Engine: 466
Class: 4x4 extreme
Used For: Holding down jackstands in the barn. (for Now ;))
Rep Power: 11 ![]() iTrader: (1)
According to the chilton online manual - if there is an adjustment screw on the rocker arm then you can change valve lash. No screws means no adjustment.
link to manual (vehicle chosen based on your profile vehicle) http://www.chiltonlibrary.com/Conten...aspx?ca=Repair |
Tweet
#6 |
Year: 1991
Make: Ford
Model: Explorer Sport
Engine: 4.0L
Class: Soon to be 4WD
Used For: Soon to be work truck...
Rep Power: 15 ![]() iTrader: (0)
The 2.9L has hydraulic lifters and lash adjuster screws... Kind of redundant, but it does lol...
__________________
1991 Explorer Sport 4.0L - 167k - DD/Work Truck "The constitution gives us all the right to be stupid... It's a treasured American right." - Phillip R. Kemmerly Ed.D |
Tweet
#8 |
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2wd
Your right guys. I must have been thinking of the 2.8l ?
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
