Go Back   The Ranger Station Forums > Axles, Brakes, Wheels & Tires > Ranger Axles
Notices
Ranger Axles Dana 28, Dana 35, Ford 7.5 & Ford 8.8
Post New Thread Reply
Thread Tools Display Modes
Old 02-07-2011, 08:05 PM   #1
MadMike
MadMike's Avatar
Year: 2010
Make: Ford Ranger
Model: FX4 offroad
Engine: 4.0L V6
Class: 4x4
Used For: Weekend Warrior
MadMike is on a distinguished road
Default A little help please
I have a 2010 FX4 4.0L, manual trans,Rancho RS5000 front and rear(the ones for torsion key lifts made huge difference), Leveling kit, with 2" blocks in the rear and T-bar crank to match the rear(total of 4" in the front and 2" in the rear), 31 spline axles with 8.8 4.10's rear diff.Magna flow exhaust and k&n intake.Now first question for you seasoned ranger owners full of wisdom what kind of front diff/axles do i have and what kind of transfercase do i have? I cant find any codes from the site charts to match. Second question im putting a 3" body lift on in two weeks so i can put my 16x8 pro comp rock crawlers with 34"x10.5 interco ssr's on now with that i wana get rid of the waste of metal open diff for a rear locker what is my best option i was looking at the lock right because of its easy intall and price with good feed back and dont wana go with a housing swap with the detroit locker any help would be sweet ass thanks
MadMike is offline   Reply With Quote
Old 02-07-2011, 08:24 PM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Front differential is a Dana 35 Standard Rotation.
The transfer case is a BorgWarner 1354 E
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 02-08-2011, 05:02 PM   #3
gettle03FX4LevelII
gettle03FX4LevelII's Avatar
Year: 2003
Make: Ranger FX4 Leve
Model: Ranger
gettle03FX4LevelII is on a distinguished road
Send a message via AIM to gettle03FX4LevelII Send a message via Yahoo to gettle03FX4LevelII
Default
for the rear it probably is a torsion limited slip or plain limited slip so if you want to put a locker in you will need to get an open housing for the locker and just reuse the ring and pinion. That locker with just replace the spider gears.
gettle03FX4LevelII is offline   Reply With Quote
Old 02-08-2011, 08:59 PM   #4
MadMike
MadMike's Avatar
Year: 2010
Make: Ford Ranger
Model: FX4 offroad
Engine: 4.0L V6
Class: 4x4
Default
Quote:
not to turn down your opinion but i was told i have an open rear diff by others and they used the traction control instead, The 2011 FX4 comes with the L.S. witch leads to the next problem will a locker work with the traction control? or would it be wise to just put the ford trac lock and the traction control would be helpful in tricking it to lock(kinda like ridding the brakes)So many ways what will work best any one out there done this to a 2010 ranger yet
Next if i have the dana 35 in the front does that mean 27 spline axles?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
