Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 3.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 02-05-2011, 12:18 PM   #1
twonole
Junior Member
twonole's Avatar
Year: 2000
Make: Mazda
Model: B3000 Troy-Lee Edition
Engine: 3.0
Class: 2WD Off-Road
Used For: Haulin' A$$ to school!
twonole is on a distinguished road
Default Thermostat question.
A couple weeks ago I had to change the thermostat out on my truck while flushing the cooling system, today when cleaning the garage I found the receipt and realized it said 180. My question is will it hurt my truck to leave it in there or should I switch it out to a 195? I just don't want to have to get a new gasket and bleed the cooling system for nothing. And if it helps the truck is running in mostly hot weather down here in sunny Florida
__________________
O o
/Ż/___________________________ _ __/
| I'MMA FIRIN MA LAZOR BAAAAAAAAAAGH!!!
\_\ŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻŻ Ż ŻŻ\
twonole is offline   Reply With Quote
Old 02-05-2011, 12:51 PM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Year: 89
Make: Ford
Model: Ranger S
Engine: 2.3L
Class: 2WD Street
Used For: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
won't hurt anything. might reduce fuel mileage by a small amount
BRUTUS_T_HOG is offline   Reply With Quote
Old 02-05-2011, 04:29 PM   #3
Rearanger
Year: 2003
Make: Ford
Model: Ranger 3.0L
Rearanger is on a distinguished road
Default
You're not going to gain anything running a cooler stat and running on rich side of mixture is not good for CAT, plugs, oil, gas mileage.
__________________
2003 3.0L Long Box, 5spd Manual, 2wd, 3.73 LS,
P235/70R-16, Synthetic fluids, Dual by-pass filter system, 60k
Rearanger is offline   Reply With Quote
Old 02-05-2011, 09:49 PM   #4
Big Jim M
Year: 2002
Make: Ford
Model: Ranger FX-4 level 2
Engine: 4.0
Class: 4x4 Extreme
Used For: DD with 31X10.50 Firestone LE's offroad with 31X10.50 MT's
Big Jim M will become famous soon enoughBig Jim M will become famous soon enough
Default
Put a 195* back in there..
Big JIm
Big Jim M is offline   Reply With Quote
Old 02-06-2011, 11:51 AM   #5
twonole
Junior Member
twonole's Avatar
Year: 2000
Make: Mazda
Engine: 3.0
Class: 2WD Off-Road
Default
Okay thanks for the help! I'll get that changed out as soon as time allots.
__________________
O o
Old 02-06-2011, 05:49 PM   #6
Froggmann
Froggmann's Avatar
Year: 1999
Make: Ford
Model: Ranger XLT Ex. Cab
Engine: 3.0FFV
Class: 4x4
Froggmann will become famous soon enough
Default
The 180 t-stat is usually used to reduce or cure pinging issues. If your truck didn't ping w/the 195, then I'd recommend running the 195.
__________________
5spd, 3.73's, 245/75-16's, Tinted Windows, Exp OHC, U/D Crank Pulley, Composite Upper Intake/Half shafted 05' TB, E-Fan, Air box Mod, CC's, 06 Tail Lights, Lowered 2.5" Rear/2" FR, Sound Deadened.
Froggmann is offline   Reply With Quote
Old 02-10-2011, 07:01 PM   #7
McCormack
Year: 2000
Make: Ford
Model: Ranger
McCormack is on a distinguished road
Default
Most people that have actually run a 180* T-stat in their Rangers report that they get slightly better mileage and a bit more power, and on top of that a cooler engine is a longer lasting engine.
McCormack is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
İ 1999-2012 / 959 Media LLC / All Rights Reserved
