Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Notices
Need Urgent Help Fast! For posting questions when you're in the middle of working on something and have to have an answer right now.
Post New Thread Reply
Thread Tools Display Modes
Old 02-03-2011, 05:29 PM   #1
gonzozir
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0 L V6
gonzozir is on a distinguished road
Default Ignition trouble
ok this jus started yesterday and I don't know what to do. I have a 1993 ranger ext. 2wd and the lights, dingers works at full strength all the way till I turn my ignition to the start position to crank it then everything dies. It's a manual tranny so to crank it I have to push the clutch in and it's acting jus like im nt pushing it in to crank it. But I can crank it using a screwdriver on the relay switch. Any I deas will be helpful. I'm thinking it's either the ignition swith or the ignition.
gonzozir is offline   Reply With Quote
Old 02-04-2011, 07:37 AM   #2
doorgunner
Lab Rat for V.A. hospital
doorgunner's Avatar
Year: 1989/1936
Make: Ford
Model: Ranger XLT
Engine: V-8...Carbed/fo-barrel
Class: 2WD Street
Used For: FUN on a daily basis!
doorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond repute
Default
I'm just guessing here......but on all vehicles, everything "dies" when the key is turned enough to the "run" position....it allowas all the battery voltage to go straight to the stater motor. You're probably just noticing it because for one second the engine isn't turning over & starting.
Maybe the electric switch on the clutch pedal isn't working....and no electricity/signal is being sent to the starter relay.
Maybe the battery is not strong enough to cause the starter to engage....
Maybe the ignition switch itself is defective (not the part that the key fits in....but the part further down the column with all the heavy wiring going into it connected by a metal rod to the key-switch)
F Y I ........................................FIX THE MOST INEXPENSIVE THING FIRST IF YOU DON'T KNOW HOW TO READ WIRING DIAGRAMS
__________________
*******My Stupied Build Thred! http://www.therangerstation.com/foru...ad.php?t=30561*******
*****All the people who's freedom of speech I fought to defend are now telling me to shut up*****
**********The Congress that gave me a Machine Gun to kill as many enemy as possible now wants my Winchester Model 1894 because I have PTSD!**********
doorgunner is offline   Reply With Quote
Old 02-04-2011, 07:42 AM   #3
gonzozir
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0 L V6
Default
It may be the switch on the clutch. But no this isn't the normal "dies" to start this just don't work. It won't start no matter how long you hold it.
Old 02-04-2011, 09:13 AM   #4
hopster
hopster's Avatar
Year: 1990,1989
Make: Ford
Model: B2,ranger
Engine: 2.9, 4.0, 5.0 can't decide
Class: 4x4,2wd street
Used For: wasting garage space
hopster is a jewel in the roughhopster is a jewel in the roughhopster is a jewel in the rough
Default
pull the connector off the clutch switch and hook a jumper wire between the two terminals if it starts you need a new switch if not you will know to move on to another component.
__________________
wtb: dana 35 ttb 4:10 gears
hopster is offline   Reply With Quote
Old 02-05-2011, 12:46 PM   #5
gonzozir
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0 L V6
Default
Ight I'll try tht if nt then back to square one
Old 02-05-2011, 02:51 PM   #6
adsm08
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Quote:
No you won't, you will have eliminated a component.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 02-06-2011, 02:11 PM   #7
gonzozir
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0 L V6
Default
Well I dunno what it couldve been other than it was too cold. Because temperature here last couple of days has been in the twenties and snow because it works fine now with the temperature in the low fifties. Is that possible?
Old 02-06-2011, 03:45 PM   #8
Spott
Spott's Avatar
Year: 1988
Make: Ford
Model: Ranger Supercab
Engine: 2.9L
Class: 4x4
Used For: Daily Driver
Spott will become famous soon enoughSpott will become famous soon enough
Default
It was likely one of a couple possibilities: a loose connection, that pulled apart a little because cold causes things to contract, or a bit of water that got someplace it shouldn't have, and didn't evaporate until it got warmer. Or any number of other little problems that make us think of "gremlins".
Spott
__________________
Build a man a fire, and he will be warm for a day. Light a man on fire, and he will be warm for the rest of his life.
Spott is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
