Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Notices
Need Urgent Help Fast! For posting questions when you're in the middle of working on something and have to have an answer right now.
Post New Thread Reply
Thread Tools Display Modes
Old 02-03-2011, 10:54 AM   #1
birdmanslopy
Year: 1994
Make: Ford
Model: Ranger
birdmanslopy is on a distinguished road
Default 94 ranger front cab mounts
theres 2 of them under the radiator, i loosened the bolts and seperated it but i dont see how this comes apart, i cant hit this one with a hammer to split it so any ideas?
im doing a body lift, only these 2 left.
birdmanslopy is offline   Reply With Quote
Old 02-03-2011, 03:16 PM   #2
alaskan155
alaskan155's Avatar
Year: 2002 1988
Make: honda and ford
Model: CR-v and Bronco
Engine: 2.4l/5.0
Class: 4x4
Used For: dd/toy
alaskan155 is on a distinguished road
Default
you loosen 1 side and remove the other, and dont worry about seperating it, take a drill bit 1/2 inch i believe and drill the mount out, then place in the order from bottom top, bolt, washer, rubber mount, frame mount, hex washer, rubber mount, spacer, radiator support, special nut
__________________
retired TRS member Currently on
Fullsizebronco.com under same name
current toy:
88 Bronco 35s stock/ no sway bars
5.0/AOD/BWt-case 210k miles
4.10 gears, Rock sliders, chopped quaters
far future mods: D60/10.25 sas/removable doors/custom bumpers
alaskan155 is offline   Reply With Quote
Old 02-03-2011, 03:57 PM   #3
wizkid00104
wizkid00104's Avatar
Year: 1994/2004
Make: Ford
Model: Ranger XL/F250 XL
Engine: 2.3L/5.4L
Class: 4x4
Used For: DD and Mild Wheeling
wizkid00104 will become famous soon enough
Default
I used the sawz-all method...
__________________
"Light beer is just wasting your time..." -My grandma
Project Little Green Turd
F250 Build
wizkid00104 is offline   Reply With Quote
Old 02-03-2011, 06:01 PM   #4
birdmanslopy
Year: 1994
Make: Ford
Model: Ranger
Default
I feel very embarrassed asking this but could you please post a picture of what the 4 cab mounts should look like as well as the radiator.
I've done your way as well as stacked it on top of the rubber and my trucks pin striping didn't match up and I was and inch or so above my bed and the beds already lifted, I'm sorry if there's any confusion but the closest I've got to having my pin stripe close was from bottom to top bolt rubber mount frame lift mount and that's it
Old 02-03-2011, 10:19 PM   #5
wr250rdr
wr250rdr's Avatar
Year: 1994
Make: ford
Model: ranger. 2.3
Engine: 2.3
Class: 2wd
wr250rdr will become famous soon enough
Default
ok here is how you get them out if they arnt rusted together, basically there is a nut built into the bottom flange on the to side of the mount, so you have flange, rubber, flange, frame, nut flange, rubber flange
what you need to do is to hold the top portion and then back the bolt out, the way i did it was soak it in pb blaster or something simmilar to help break down the rust. then i drilled two holes in the top flange and used a motorcycle flywheel holder and it came apart just fine
wr250rdr is offline   Reply With Quote
Old 02-03-2011, 10:33 PM   #6
birdmanslopy
Year: 1994
Make: Ford
Model: Ranger
Default
ok i got the front mounts out but ive ran into the problem about the blocks.
any way i put the blocks its either lower or higher than the pin striping on my bed.
Perfect example.
oem setup bottom to top would be nut washer lock,then bushing, then frame, then bushing and top lock then bolt in the cab.
i jacked my cab up slid my block on top of my mount not messing with anything on all 6 and the truck sat about 2 and a half inches higher than the bed.
then i took the block out and removed the top bushing and just used the block in its place and tighetened that down to get it about an inch lower than the pin striping.
where am i going wrong? this is getting nerve racking being this has been a week long project.
if it isnt too much to ask could you take a picture of your cab mount setup as well as your radiator mount setup and post it please i dont see what im doing wrong here and its driving me nuts
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
