Go Back   The Ranger Station Forums > Engine & Transmission Forums > 4WD Systems
Notices
4WD Systems Transfer Cases & Locking Hubs. Forum sponsored by The Shiftster
Post New Thread Reply
Thread Tools Display Modes
Old 01-25-2011, 11:53 AM   #1
clevjake
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Getting chicks...I mean getting to work
clevjake is on a distinguished road
Exclamation T-Case/Hub Problem!!!
Hello everyone,
I'm new to this site, but an avid do-it-yourselfer like most of you. I've had my Ranger for about six years now and here recently (last winter and this winter) I've noticed some problems with my 4WD:
1) The auto-locking hubs never unlock permanently. They disengage for awhile and then lock back in randomly when I turn. I ordered manual hubs to replace them and plan to do so as soon as they arrive. Any particular advice other than the obvious instructions?
2) This winter I've noticed that the transfer case is awfully noisy. When I'm in 4hi, it whines very loudly when the truck is in motion. What can I do to investigate or solve this?
Any help is greatly appreciated.
clevjake is offline   Reply With Quote
Old 01-25-2011, 06:41 PM   #2
feellnfroggy
feellnfroggy's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
First thing you need to do is start checking bearings and checking diff fluids. The whine most likely is your front ring and pinion needing some new fluid. the unlocking of the hubs could be any random thing, the way they work is when the axles are torqued they engage the hubs to turn the wheel, so if you diff fluid is burnt and the front gears are stiff in movement then possibly turning (which causes one axle to speed up) is trcking the hubs into mechanically engaging. Im not saying 100% but a possiblity. Also when removing the hubs to check your bearing, check hub lubrication, it should be very mildly grease. Not dry.
__________________
This signature has encountered technical difficulties...
Quote:
Originally Posted by Hopman View Post
Like I say to the newbies who join us: "Pull up a chair, grab a cold drink, & watch for low-flying BS!!!!"
Quote:
Originally Posted by Shran View Post
Used to happen to my mom's Grand Marquis all the time when we took it offroad. Don't worry about it.
Agreed. "Whiskey Tango Foxtrot" doesn't begin to cover the ugliness of this thing.
feellnfroggy is offline   Reply With Quote
Old 01-25-2011, 11:01 PM   #3
clevjake
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
Thanks for the reply. I picked up some Mercon ATF today and my new manual hubs should be here any time. So, I'll swap those out and make a fluid change all at once. Anyone done this before that might have some advice on any headaches to watch out for?
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
