i started my SAS today, even though it was pouring, i couldn't resist. So far i got all the small things disconnected from the axle; brakes, breather hose, steering, took off the tranny X-member, and also got the truck stable enough to work under. I plan on getting the d35 out tommorrow. I only worked on it for about 2 hours today because of the rain, otherwise the d44 would be ready to go in. I plan on getting a bunch of pictures tommorrow if the weather is nice. I actually remembered to measure from the ground to the fender to see how much extra lift i will get in the end. Ive done 2 other lifts where i forgot to do it until it was too late.
I found the hardest part so far was getting the dang driveshaft off with those stupid torx bits. Man i hate those.
The axle going underneath is a 73' EB 44 with a no-slip locker and 5.13 gears. I have the FW axle shafts with the larger 760-X u-joint being prepared to put in it. I didnt shorten the longer side, just bought a 4340 replacement from broncograveyard. Then ill run standard brakes and warn premium hubs. I got the 3" BC bronco coils, so im curious on how these work out in terms of ridability and flex. Ill be getting the pictures up when i go back to school in a week. I dont have internet on the computer that the pictures are going on.
ive been trying to find time to do this since may. Im pumped that its finally happening.
stay tuned for more sas action!
