| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#1 |
Year: 2006,
2013
Make: Mazda,
Chevy
Model: B3000,
Camaro
Engine: 3.0L Stick, 3.6L Stick
Class: RWD Street, RWD
Used For: Reminiscing... RIP B3000
Rep Power: 9 ![]() iTrader: (1)
Hey guys, every forum I visit I pose the same question... Do you downshift to aid in braking?
![]() I'm interested to see what people do and how they drive their stickshifts. I happen to downshift, got used to it in my old Rav4 and I have carried it over to my truck. IMO, I save my brakes and I gain a bit in MPGs, nothing is completely proven. BUT, I have driven the truck without downshifting on one of my tanks. It was the worst gas mileage I had in a while, so I quickly returned to my fun downshifting ways, lol.
Tweet
#2 |
Year: 1993
Make: ford
Model: ranger s/c
Engine: 4.0/245 c.i.d.
Class: 4xford
Used For: gitten' it done!
Rep Power: 16 ![]() ![]() ![]() iTrader: (0)
i downshift while braking, just habit i guess, its how i learned to drive, dont even give it much thought.
__________________
at the corner of "walk" & "dont walk" cardomain link:--> http://www.cardomain.com/ride/3216869 1993 ranger s/c 4.0 hurst-equipped 5-spd,3.73s ,4x4, milemarker hubs, black grille guard/tube steps,summit rear diff cover with bearing load supports. 117K & still going strong. http://www.myspace.com/small_dog_trucking |
Tweet
#3 |
Year: 1997
Make: Ford
Model: Ranger
Engine: 2.3
Class: 2wd Street
Used For: summer/fall vacation use,hauling wood,hunting,D.D.
Rep Power: 12 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I have owned a 5spd since '92 and have always downshifted to aid in braking.
__________________
I am invisible |
Tweet
#4 |
Year: 2002
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Daily Driver
Rep Power: 20 ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I only do it in big trucks and semi's. Only do that due to weight of what I'm pulling, never have in small cars or small trucks.
__________________
Click --> 2002 Ford Ranger 4x4 |
Tweet
#5 |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Engine: 4.0-5.2 Turbo
Class: Real 4WD, 3WD.
Used For: Going where I point it-Going fast
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
Most people don't do it correctly, I downshift on hills but usaully not to slow down unless I will be speeding up again. Brakes are cheaper than replacing synchros which you will wear out faster if you don't double clutch. It's amazing how many people I ride with that downshift every single gear every time they stop, it just isn't necessary.
__________________
88 Bronco II, 4.0L, M5OD, 4.56s, Aussie Locked 8.8/D35, 1354M, 34" LTBs 95 Dakota CC, 5.2, 5 Spd, 2WD,Turbo, Megasquirt, 3.55s, Locked |
Tweet
#6 |
Mall-Rated
Year: 1990,1994
Make: Ford
Model: Bronco II, Ranger
Engine: 2.9L, 4.0L
Used For: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I tend not to in routine driving. I figure if saving some wear on my tranny synchros means I have to replace brakes a bit sooner, so be it (it's a lot easier to replace brakes).
I do use a low enough gear to avoid riding the brake excessively down a long grade however. Edit, yeah exacty what Hahns said lol
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s Last edited by 4x4junkie; 01-17-2011 at 06:24 PM. |
Tweet
#7 |
Premium Member
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 3.0
Class: 2WD Street
Used For: Summer Beater
Rep Power: 55 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (2)
I think the whole secret in down shifting is learning to match the RPM's. I got so good with my old 4 speed, I could do it with out even using the clutch. Takes practice not probably not reccomended. I never give a thought to downshifting, just do it.
Dave |
Tweet
#8 |
Year: 1995
Make: Ford
Model: Ranger
Engine: 2.3l of fury
Class: 2WD
Used For: DD and mall crawlinz
Rep Power: 15 ![]() ![]() ![]() ![]() iTrader: (1)
I don't. I'd rather replace brakes than a transmission or clutch. I will however downshift for hills to avoid overheating the brakes. But I do coast in gear to stop lights and signs and throw it into neutral before the engine starts to lug.
__________________
1995 XLT 2wd, 2.3, M5OD-R1 1993 XLT 2wd, 4.0, M5OD-R1 1991 XLT 4wd, 2.9, FM146 See my build thread
Tweet
#9 | |
Year: 2006,
2013
Make: Mazda,
Chevy
Model: B3000,
Camaro
Quote:
Is that what you're saying or would you consider my downshifting excessive as well? |
Tweet
#10 | |
Year: 88-95
Make: Ford-Dodge
Model: BII-Dakota
Quote:
One of the best things you can learn to do is double clutch your downshifts, this will take a lot of work off of the synchros.
__________________
Tweet
#11 |
Year: 1988
Make: Ford
Model: Ranger SXY
Class: 4X4
Used For: Doing dirty deed's dirt cheap.
Rep Power: 38 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I duece the clutch too but rarely downshift past 3rd.
__________________
88 Ranger http://www.cardomain.com/ride/2459246 "You have come to take our evil black guns? heh heh be right with ya there mister."
Tweet
#12 |
Year: 2003
Make: Ford
Model: Ranger xl
Engine: 2.3l
Class: 2wd
Used For: A-B
Rep Power: 9 ![]() ![]() ![]() ![]() iTrader: (0)
Speaking of clutches and synchros, mine won't go into first very well, and third is as low as I can downshift. Also, sometimes I'll stick it in first only to have it pop out of gear when I let off the clutch. Should I replace/fix something?
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
