Redneck Ranger
DRIFTGOD187
15+ Year Member
hello, i have been visiting this site for a long time but finally decided to register.
Redneck Ranger
Redneck Ranger
i bought this truck last year for $400.00 just to drive to work, it has a 3.0 V6 and push button 4WD. the 4WD has never worked because the previous owner removed the actuator motor from the transfer case and cut all the wires, he also lost the mounting bolts. the auto locking hubs were stripped out and it had 4 different tires on it.
the tires i put on it last year are 235/70/R15 WINTER FORCE and i payed around $350.00 for all 4 tires.
Redneck Ranger
i bought a used actuator motor for $81.00 and got the bolts i nedded for free.
here is a pic of the actuator motor:
Redneck Ranger
after installing the actuator motor it was time to fix the auto locking hubs, i decided to swap them with manual locking hubs. i bought the manual locking hubs and a conversion kit for $250.00.
here are the hubs i bought:
Redneck Ranger
here is the auto locking hub next to the manual locking hub:
Redneck Ranger
Redneck Ranger
after converting the front end from auto locking hubs to manual locking hubs it was time to test it.
this snowpile is about 4 feet high, i drove up and down it a few times, and also drove through the front yard that had about a foot of snow on it with no problem.
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
and to give you an idea as to how small my garage is, here are some pics:
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
the truck is now in the garage again, but this time i have it over to one side so i can work on the exhaust.
edit: i changed my speedometer cable and speed sensor, changed my heater core and i replaced the exhaust, flushed the coolant system, changed the oil, and got the truck inspected.
Redneck Ranger
Redneck Ranger
Redneck Ranger
i took the ranger out in the mud for the first time today, the pics arnt very good (lighting) hopefully the rain we are getting wont wash it so i can get beter pics in the sun :D
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
no sun today, but it looks beter with the mud dry :tu:
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
i basicly just drive this truck to work, but im also looking for another truck with a good body on it possably a 2001 because i like the way the front end looks, if i end up changing all the body parts exept the cab i might put a 3 inch body lift in it.
this is the front end i like, if i can find one wrecked in the rear or with a blown motor i might be able to get it cheap. the only problem with converting it would be if the radiator core support is different.
Redneck Ranger
eventually i would like my truck to look something like this, different front end of course.
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
my antenna ball liked the way the 4WD works too :thumbsup:
Redneck Ranger
Redneck Ranger
the ranger bringing home my new toy :D
Redneck Ranger
Redneck Ranger
the ranger is in the garage again undergoing some minor surgery :D
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
painted the box & cab flat black:
Redneck Ranger
got my parts truck tuesday, sofar nothin but good news on the parts i need for mine :tu:
Redneck Ranger
Redneck Ranger
while the tow dolly was there we pulled my truck out to get my lawnmower out of the bed.
Redneck Ranger
Redneck Ranger
i swapped rear windows, now mine has a slider.
Redneck Ranger
Redneck Ranger
i stripped down the front of the parts truck and part of the engine, also swapped seats.
Redneck Ranger
Redneck Ranger
Redneck Ranger
the parts truck now has my front end on it :D
Redneck Ranger
Redneck Ranger
here is a pic of the engine on the parts truck. i removed one of the heads because mine has 2 cracks in it, just that head is worth the $250.00 i payed for this truck ;)
Redneck Ranger
got it back together but the timing is way off, seems to run strong and has heat. no leaks yet exept the thermostat housing.
painted the valve covers ford blue just for the hell of it lol.
Redneck Ranger
here is a pic of it with the front end from the parts truck, bumper needs adjusting but i think it looks good.
Redneck Ranger
more pics.
in the rear pics you can see the rear windows i swapped, the third brake light on my truck also came off the parts truck. the rear bumpers will be swapped too.
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
i swapped rear bumpers and aligned my front bumper. i also picked up a bedliner for free.
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
the parts truck had a kenwood cd player in it so i installed it into my ranger:
Redneck Ranger
i looked for snorkels online and i saw a "cowl snorkel" that somebody built on this site and decided to build my own. i didnt like the material the other person used, so i made mine out of PVC.
first i removed the air box off of my parts truck and sealed the filter housing with RTV:
edit: the first 2 pics show the air box i used and the position of the stock inlet.
Redneck Ranger
Redneck Ranger
Redneck Ranger
i then took a 3" to 2" PCV reducer and connected it to the outlet on the airbox:
Redneck Ranger
i then used 2 pieces of 2" PCV pipe and 2 90 degree fittings to route the piping to the inner fenderwell:
Redneck Ranger
Redneck Ranger
from here i cut a hole in the cowl housing and used 2 pieces of 2" PCV, a 2" coupler and a 90 degree fitting to complete the routing of the snorkels piping:
Redneck Ranger
now instead of being limited to driving through mud/water up to the bumpers, i can drive through mud/water up to the cowl.
Where are you located? I'm getting a Ranger with the front end you want but will be swapping the grille/hood for an Edge/4wd grille/hood. My hood is fine but the grille surround is cracked and I'd let it go for cheap if you're anywhere near me.
im in NEW YORK but to be honest i dont have money to buy new parts right now, i appriciate the offer though.
i painted the pvc pipes, core support, and inside the fenders flat black. i also reinforced the snorkel with exhaust clamps and band straps.
Redneck Ranger
Redneck Ranger
Redneck Ranger
Redneck Ranger
what part of new yourk you from
DRIFTGOD187,
I was looking thru your saga and found it difficult to keep track of which truck was which.:icon_cheers:, but it all looks good, and doesn't look like you'll have any problems getting thru the snow and mud.
i live in PAVILION.
the parts truck had this viser thing on the back window so i put it on my truck:
Redneck Ranger
here are some pics of the interior, the seats are from the parts truck:
Redneck Ranger
Redneck Ranger
i painted the bottom of the fenders flat black to match the rocker panels:
Redneck Ranger
i painted the piece from the throttle body to the mass air sensor ford blue when i painted the valve covers, i didnt put it on the truck until today because i thought it stuck out to much:
Redneck Ranger
i also took the ford emblem off of the parts truck tailgate and put it on mine:
Redneck Ranger
i decided to give the snorkel more air so today i added a vent. this vent is used for campers Danco
Galvanized Plumbing Vent Cap for Mobile Home
and it worked perfectly.
first i drilled a hole in the cowl with a 3 inch dewalt hole saw, then i used a 2 inch coupler, 2 pieces of 2 inch PVC pipe, and a 90 to bring the snorkel piping up through the cowl.
Redneck Ranger
here is the vent before bolting it down and painting it:
Redneck Ranger
Redneck Ranger
here is the vent painted and bolted down:
Redneck Ranger
Redneck Ranger
Redneck Ranger
the vent is very low profile, and to extend the snorkel up to the roof i just have to take the cap off and connect a piece of PVC pipe with a rubber coupler:
Redneck Ranger
after installing the vent i decided to repaint the cowl and the vent, i will get beter pics when its not so dark out:
Redneck Ranger
Redneck Ranger
amazing work!!!
i hope someday i can get a beat up ranger and repair it like u are doing yours!
keep u the good work man, looks great, nothing like the crap u started with :D
thank you :icon_thumby:
here are pics i took this morning:
Redneck Ranger
Redneck Ranger
You stole that truck for $400. I would have scooped it up in a heartbeat.
Upcoming TRS Events
