3.0 valves AGAIN
crf250r6
15+ Year Member
about a year ago i had new valve seats put in my heads, about 3 cylinders were low on compresion, it would start idleing rough and if let idle long enough cylinders would die. i heard it was a comon problem, seeing is how 2 other buddys rangers did it too. i think its within certan years too( mine is 06), but after a year its starting to do it again, orange engine a machine did my heads, they told me they used hardend seats. i want to find out what causes this, is it exahust temp getting too high? i was thinking of punching out 2 of the cats to free it up. i know it gets hot cause it was the exahust valve seats that were bad, and ive had ford replace a exahust manifold once since it warped, and ive had to weld one that cracked, and some of you may say replace the heads but my buddy had ford replace them and they said they updated them with hardened seats and his started doing it again too. just wonderin what everyone thinks of it, i dont want to pull my heads every 10,000 miles.
i have a magana flow on it, just a weld on muffler, its an auto, and i dont redline it often at all, the shop that did is supposed to be a good shop that has been around for a long time. theirs has to a problem and a way to solve, cause like i said my got new heads from ford and it just did it again, if the cats are bad will that cause it?
if they fit you could get heads from an older truck even a 98-00 model and try them
i thought about getting heads from an older truck but i dont know if they will fit, no mods on it besides a k&n intake.
ill tell you what the ford place here told my buddy on his 04 when he burned his valves out. the tune on the newer rangers (99 up) is super lean and any exhaust modifications will burn them out. it causes too much exhaust flow and the temperature in the chambers goes into the exhaust ports and cooks them. he had a magnaflow 1 in 2 out and had all cats when he burned them out, then removed all but the ones at the headers, which warped his heads. he slung two rods one thru the oil pan another thru the block at 210k going back and forth to texas for court. hes on a new engine and looking into a programmer to richen the mix and bring the head temperature down. keep in mind richening the mixture will skrew an emissions test, luckily down here in louisiana we dont have emissions except for baton rouge. as for the older heads bolting on, all 3.0 will but they dont have the same chamber design and the tune is wrong for those heads. easier to go from a 94 to a 99 up than downstepping requires retuning to run correctly from what ive been told.
when my buddys did it his truck was stock, so is it the actuall heads that are the problem or did they make them run to lean.
the tune on the engine on his when it was new cooked his valves and the exhuast helped finish them off, shop said it looked like it was done over time. they ruled it back to used o2 sensors not giving the proper signal but they werent worn enuff to throw a cel. they checked the computer and even reflashed it said it had the right tune they just seen it in a few trucks over time. said keep an eye on all 4 o2 sensors and change them around 50k miles to curb it from happening. btw you ride an 06 crf250r? my coworker had one and i used to race yfz450s, im a certified yamaha tech at the local honda/yamaha dealer lol.
i did have a crf 250 now i have a crf450.
can the maf cause it to run even more lean?
Yes the MAF can cause a lean condition. It seems likley to me that your air intake is causing problems. If it's over oiled, that can cause issues with your MAF. High flow filters by nature allow more particulates into the engine as well, which can cause problems. (I only mention this because it looks like you spend a lot of time in the desert)
I'd go ahead and check the cats too. If one is plugged, it can cause excessive heat buildup, which could crack or warp your manifolds, which can burn the valves.
How lean would it have to run to burn valve seats while not showing signs of poor running, hard ignition and sending code? Did you inspect the condition of the spark plugs to confirm lean burn?
i always check the intake tube to make sure nothing goes past and nothing does, i dont know if it is running lean, it does ping some times, is that a sign of it running lean.
he has a drop in filter but he can still overoil it and the oil get on the heated wire element of the maf. this will cause it to read less air coming into the engine and lean out, hence the ping. the ping is detonation from lean condition, thats your issue buddy.
If combustion temps were that high to burn seats why weren't the valves burnt, surely they have less ability to cool?
Upcoming TRS Events
