- Aug 26, 2007
- Age
- 37
- waterford michigan
swapping a carbed 302 in my b2 which is currently the 2.9 electric puel pump in the tank. When swapping in the 302, do u run the mechanical pump on it or keep the electric pump and use a pressure reducer? If the electric pump can no longer be used how would I cap off the top of the gas tank where the electric pump goes?
Fuel lines..can i reuse the stock line and attach a fuel block then a flexible hose coming off that? Is it possible to run a long flexible hose or should i keep the hard line?
Let me know how u did yours and whats the easiest way. Sorry for alot of questions!
