- Mar 7, 2009
- Age
- 35
- Fort Madison, IA
I figured I should start a build thread for Liz,
Its a 1994 4x4 ext. cab Ranger, 3.73 gears, D35 T.T.B. front, 1354M Transfer case (was a 1354E case) , M5OD trans, 8.8 L/S rear, 4.0 O.H.V., Warn manual hubs, running 30/9.50R15's on the rear with 235/75R15's up front (not for long, i hope)
So far plans are J.D. 2.5-3" suspension lift, with a 1-1.5" body lift, built up 4.0, build a real rollbar, winch front and rear bumpers, half doors, C.B., Bronco II or a 70's F-150 rear tank, and re-gearing to 4 something gears and locking the D35 & 8.8 to finish her up.
So far I have Installed a 1354M transfer case from an early 90's ranger, 1999 Escort sport Zx2 bucket seats, I've killed off the 5 cylinder 4.0 with loads of water, mud and gas, I'm at the tail end of installing a 4.0 from a 92 exploder, and a M5OD from a 96ish Ranger.
I might also have a line on a D60 and 9" from a certain 78 F-150 I used to own, although I'm looking (passively) for a sterling 10.25 rear axle, and I'll probably be building a center console to house my C.B., Winch switches, and cupholders again!
enough info, time for pictures!
Pics of when I got it
Changing the beyond pooched front u-joints
the cut down rollbar from Beef
the rollbar with the Baja's lights
Front view
The final wave goodbye to the 1354E, lol
Loosing the cupholders is a sad affair
The creek I got stuck in and later blew up the motor in
in the middle of the motor swap
her first taste of tree rash
To better see the dents that magically appeared...
lightly "modified" taillight
Not the last body damage she'll see but it'll be a while before I go play that hard again, maybe.
Front view
at least the new slave cylinder didn't leak out too. tomorrow I'll be buying about 5 big bottles of DOT 3 brake fluid, along with a new hydraulic clutch line (tired of playing with whats left of the old plastic collar) and maybe a new master cylinder too, for S&G.
its acting like it still has some air in the line, if you put it in gear while the engines off, press the clutch in while it rolls you can hear the clutch slightly rubbing the pressure plate, its enough to not be able to shift it into 1st gear while running, while rolling down the road you can force it into other gears. a friend that stopped by said that it could be that the clutch is thicker then O.E. or that the slaves are shorter then O.E. and another buddy said that it could be the syncros in the trans causing it to not want to shift into gears, I'm halfway temped to pull this "new" trans out and put in the old growling M5OD back in to drive it....
