98+ Motor mount plates 2wd coilspring
AlwaysOnKill
10+ Year Member
Shrevreport La
Who has or makes motor mount plates for 98+ 2wd coil spring trucks ? I will pay for a set right now . I went to install the motor today and I said to myself that's not going to work .:) Id like to use the stock mounts that are already in the truck .
The only plates I've seen for the late model 4x2 use the stronger 4,0L isolators. I and several others have those plans.
Dave of the Nord
Dave of the Nord
Guess there custom blue printed plates ? How do I become one of the few to get these cutstom plates .
Have to see how good I am at finding them. Must be getting better in my old age, forgot you could attach pdf. I also have them in a .dwg file if you have a machinest who uses CNC. The info from Brian is also helpful
Dave of the Nord
Dave of the Nord
Wow .. Thank you sir . I do have a local machinest that could do it . Can you please pm me that file ?
Well, don't think I can attach a .dwg file here or in a PM. Will need an E-mail address.
Dave of the Nord
could you send me diagram for these plates:icon_confused: joey197478@yahoo.com Thanks! Joe
This thread was dead.. I will answer your request here knowing that permission has been granted by those in the design of these mounts. I hope these are good enough for you to use. If not I wish you luck
thanks
Thank you very much these will help alot. One question do you have to use the 4.0 mounts or will my 3.0 work?:icon_confused:
Thanks these will work great Joe!
Those plates are designed to work with the 4.0 OHC mounts.
Dave (Amherst design)
I was under the impression that the 4.0 ohv had the same plates if not will these work
Upcoming TRS Events
