Ryannn
1989 Ford Ranger, Paid 400$ for it.
1 Week after I Bought it
Tuned it up, New Oil, Cap, Roter, Plugs, Belts.
Swapped the Headliner out.
New Fuel Pump.
Removed Some of the Rust and repainted over it. ( Flat Black Spray paint )
2/28/11 - New Alternator, replaced the Original MotorCraft one that was 22 years old with a Duralast one from AutoZone with a lifetime warranty.
3/9/11 - New Thermostat.
3/14/11 - Wheelin
3/24/11 - Another new Thermostat. The one I got on 3/9/11 Malfunctioned and would cause my heater to get super hot then not blow at all, and other things. This one seems to be working like magic.
3/25/11 - New Temperature Gauge Sending Unit, New Oil Gauge Sending Unit.
4/8/11 - New Dashboard face plate. The Old one was becoming discolored and had sun damage. Started my Engine Swap, Found a Good donor and the local Pick N Pull and has only been in the yard 2 months it was in a front end accident. Everything was intact on the engine, He had a Pushbar/Brush Guard on the front which saved the engine.
4/14/11 - Removed my Spare Tire/Carrier. Added my "TheRangerStation.com 20 Horse Power Sticker" To the rear window.
5/9/11 - COMPLETED MY ENGINE SWAP! New Clutch Also.
5/19/11 - Replaced my Idle Air Control Valve, Throttle Positioning Sensor, O2 Sensor, Cap and Rotor.
Here is all the old stuff.
7/21/11-
The Black Grill!
Also, Throttle Cable Tighten Mod.
7/30/11 - New Tires!! Big Foot Premium A/T 235/75/15
New Fuel Pump.
3/14/11 - Wheelin
7/21/11-
The Black Grill!
