Painted Deerhoofs?
farmer
Rochester, NH
Mix of 78-96
13ish
39.5x15.5
Has anyone painted their stock "deer hoof" wheels? mine look crappy and I'm thinking of spraying them black
I think that painting factory aluminum wheels looks like shit, but that's me.
I figured it probably would but its easy to ask others opinions before I mess up a decent set of wheels. I may still try to paint the inserts on the holes and the center caps just to break it up.
may i suggest getting a junk rim from a pic and pull to experiment with. that way you don't mess up your rims till you know how you want them, I've sandblasted a set before with great success. then used self etching primer.and did them color matched to the body color with a chrome painted outer ring.
Well, I did mine about 2 years ago, and I am still as pleased now as I was then. Just used some really high grit sandpaper, & some high temp enamel. Here it is.
Painted Deerhoofs?
Painted Deerhoofs?
Painted Deerhoofs?
Now once again take into consideration, this is a 2 year old paint job on a 17 year old rim (and some old tires).
wow that did come out nice. i like it
Yeah, it was 400 grit. You should of seem it when it was new. I originally did it because of discoloration from brake dust. No problems now.
do it. just remember thy only come out as good as you prep
Wow. I never knew those wheels could actually look cool. I hated mine from day one. Nice work. :icon_thumby:
Is that a 2wd with the factory size tires? 'Cause that looks really good. I might do that to mine in the meanwhile.
not deerhoof rims, but cheap factory silver steelies i painted black on my 00
Painted Deerhoofs?
Painted Deerhoofs?
