93' Navajo
Slingblade
Oshkosh, WI
Thought I would put the finished truck on the front page.
basically this is going to be a suspension swap from my 93' ranger
so here is what i accomplished tonight after work
got the axle and all the stock brackets out of the way. Now I need to get the axle and suspension out of the ranger to transplant it.
I thought I would roll one of the tires under it to see what it will look like.
The truck should sit about 3-4 inches higher when the suspension is under it.
Sweet! SO whats the plan? Why the parts from the truck?
Well now I have a wife and a 2 year old and it won't be long until I'm going to need a back seat for wheelin with the little one.
Ok now here is what I got done tonight.
I got the ranger striped of its front suspension and axle.
And here is what I got harvested to put on the Navajo.
So hopefully tommorow I will get time to start putting some of this stuff back together.
now its time for a progress report, been a little to busy to post lately but I found some time.
Got the front end done woot:yahoo:
original.aspx
original.aspx
Hey Man, you should do the blinker mod to the side markers and get rid of those little blinkers. I just did it to my Navajo frontend on my B2 and it works great! Took all of 20 minutes to do.
almost done, when i first put the rear axle under the Navajo, I decided to try using the 2.5" blocks but soon discovered that the rear was then 3in taller than the front. Pulled the blocks out and got new u-bolts and here is how it turned out. I just need to make an upper shock mount crossmember to use my skyjacker shocks.
original.aspx
original.aspx
original.aspx
Trucks been done for a couple weeks just haven't had time to post up pics yet.
Now I just need to upload the pics from the breakin weekend.
Chris
