Serving 1984-1990 Ford Bronco II Owners & Enthusiasts
Home Library Bronco II's For Sale Bronco II Gallery B2C Shirts & Decals The Ranger Station
Go Back   The Ranger Station Forums > Truck Discussions > Bronco II & Explorer Specific
Notices
Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral
Post New Thread Reply
Thread Tools Display Modes
Old 11-07-2009, 05:48 PM   #1
97fordrunner
97fordrunner's Avatar
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Used For: Weekend Wheeler
97fordrunner will become famous soon enough
Default How much voltage to fuel pump?
I got a '89 BII the fuel pump in tank wasn't working due to some moron cutting just about every wire about three times and twisting them together so with that all fixed I am getting about 6 volts to the pump and no workie. With a 12 volt jumper the pump works and pumps. Is it supposed to be 6 or 12 volts and has anyone had an issue with this before?
__________________
'97 Ranger 4.0, Auto 5" custom Suspension 3" Body lift. 35" Baja Claws, 4.88 gears Rear locked. Warn jeep Hubs.
Build Thread
"since we didn't know what to do, we sat down and did nothing" - James May, Top Gear BBC
Ranger Militia Member
97fordrunner is offline   Reply With Quote
Old 11-07-2009, 06:17 PM   #2
Earl43P
Premium Member
Year: 2000
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4WD
Used For: DD
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Definitely 12v.
Earl43P is offline   Reply With Quote
Old 11-07-2009, 06:48 PM   #3
97fordrunner
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
any ideas why I would only be getting half that thru the Fuel Circuit?
__________________
Build Thread
Old 11-07-2009, 07:39 PM   #4
03ranger4x4
Year: 2003
Make: Ford
Model: Ranger
03ranger4x4 will become famous soon enough
Default
i have a few ideas, you could always check it out.
Are you sure your only getting 6v AT the pump ONLY? Stupid question, but its best to start with the simplest cuases 1st before going more in depth. Check the battery terminal JUST to be sure. even if the truck cranks over fine. you never know.
another thing, are you checking voltage at the pump while its connected, or at the connector while the pump is not connected. If you are taking it with the pump connected, theres a chance that the voltage is fine, and the pump is siezed up. If thats the case, the pump would be drawing maximum amperage, and given the size of the wire, or the amount the relay or fuse is able to carry, it could technically drop the voltage of the fuel pump circuit that low, possibly even without blowing a fuse.
then theres another thing, check the relay connections, and scan the wire (to the best you can, i know it can be tricky) all the way to the pump, and check for any shorts to ground or any partialy opens in the wire. The relay may also be bad, cuasing only a little voltage to slip by, but ive never seen this happen. Its unlikley, since its typically a part that fails complelety when it does go out. but it can happen, and given your readings, i would check it out to be sure.
I would suggest after proving that the fuel pump itself isnt bad, is to disconnect the battery and disconnect the pump connector, and take ohm readings from the fuel pump postive wire to ground at all the pionts you can running working towards to the pump to see if it is shorting to ground anywhere, even if you get a partial reading, that is bad. You should see infinate ohms (open) all the way to the pump.
Good luck, this problem is rather simple,and after taking the checks i menchined,you should narrow down the cuase in no time
03ranger4x4 is offline   Reply With Quote
Old 11-07-2009, 08:00 PM   #5
97fordrunner
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
I was checking it at the connector with it unhooked from the pump. The pump operates ok with a jumper. I will check the relay for sure. I replaced a ton of wire that had opens and twisted wires it was a terrible mess really. Thanks for the info I'll look at all that tomorrow
__________________
Build Thread
Old 11-08-2009, 06:43 PM   #6
97fordrunner
Year: 1997
Make: Ford
Model: Ranger
Engine: 4.0
Class: 4x4
Default
Got it running, Like a Top for that matter, found a bad wire and also a twisted fuel line
__________________
Build Thread
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
