| Home | Resources | Tech Library | Magazine | Video Gallery | Truck Gallery | Shirts & Decals | Parts |
| Bronco II & Explorer Specific Also check out our Bronco II section at the BroncoIICorral |
Thread Tools | Display Modes |
#1 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: DD and weekend offroader
Rep Power: 0 ![]() iTrader: (0)
I have a pretty much all stock '89 Bronco 2, want to get a 3 or 4 inch body lift first of all and then I was wondering how big of tires I could get without rubbing issues? I know I could probably get 31's on but would 32's be pushing it? I dont take it hardcore off roading or anything, just a daily driver occasionally take it on a few trails. Any help would be greatly appreciated!
Dusty |
#2 |
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
Used For: intertainment
Rep Power: 4 ![]() iTrader: (0)
31's would be good 32's might be a little tight.
__________________
1989 Bronco II, 4x4, 2in. body lift, 2.9 with crane cam, MSD igintion chip, air/fuel ratio chip, centerforce clutch, ARP bolts in motor. |
#3 |
Year: 1989
Make: Ford
Model: bronco II
Engine: 2.9
Class: 4x4
and honestly, i wouldnt go any bigger then 33's on are weak d28 front axles, they break pretty easy.
__________________
#5 |
Premium Member
![]() Join Date: Dec 2007
Year: 84, 86 & 89
Make: Ford
Model: Bronco 2's
Engine: 2.8 & 2.9
Class: 4x4 & 2WD
Used For: Holding down the drive way/ DD
Rep Power: 6 ![]() iTrader: (0)
i personaly run 31x10.5's with a 3" BL and some finder trimming but the trimming is due to the springs being flat. i ran 33x12.5's on my 86 with a 3" BL but i had to trim the fenders on it because they would rub on the very bottem corners of the fenders when turning. so depending on the condition of your springs and the width of the tires along with the back spacing of the wheels it could work out. and fyi ive never had any troubles with the d28 when running the 33's, i did manage to blow up my 7.5 however.
#6 |
there is no such thing as a 4 in body lift unless u ghetto fab one i had a 3 in body lift on my ranger alot of bad trouble came with . just get a lift or sas it
__________________
Ummm your post is hard to read & understand, made my brain hurt ! Would you consider editing it ? 92 ford explorer sas leaf front,d44/d60 38s tsl, drive flanges, 5 ton steering, gutted inteerior |
#7 |
Premium Member
![]() Join Date: Sep 2009
Year: 1989
Make: Ford
Model: Bronco II
Engine: 2.9
Class: 4x4
Used For: everything. its a B2!!
Rep Power: 3 ![]() iTrader: (1)
you should be fine to run 32's with a 3" body lift. just be sure to get everything tight. then re check/tighten everything after putting some miles on it.
what size wheels are you going to run? what kind of back spacing. that will all depend on if you have to do some trimming to? whats your gear ratio? |
#13 |
March 2009 OTOTM Winner
Year: 1991
1984
Make: Ford
Model: Ranger
BII
Engine: 2.9, 4.0
Class: 4x4
Used For: running stuff over
Rep Power: 9 ![]() iTrader: (2)
look in the tech library there is a chart there that will help you to identify what ratio is in your axles.
| Bookmarks |
| Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
| Thread Tools | |
| Display Modes | |
Similar Threads
| Thread | Thread Starter | Forum | Replies | Last Post |
| will i lose power by lifting my 2.3l ranger and putting on 31in. tires | blindguy315 | 4-Cylinder (2000 & Older) | 6 | 03-17-2008 09:49 AM |
