coilovers
4bangeranger
i want to put some coilovers on my 93 and just need to know if i drop it 3 inches in the front with the stock i beams. about how bad will the camber be???
You will have the same results as if you put 3" drop coils on. It'll be bad more then likely. That isn't saying you won't be able to get it back in spec though, each truck varies slightly. A company use to make 3" drop coils and someone here had them. They were able to get their truck back to spec with the aftermarket eccentrics.
James
He's right--I lowered my '89 2wd xlt 3" on the front--it threw the camber IN 1.25" /-----\ & the toe-in went OUT .75" <------> I followed the alignment procedures in the Tech Library & got the camber perfect by installing a pair if eccentric adjustable camber bushings (0 degrees to 4 degrees). The none adjustable bushings cost much less, but you have to know exactly the degrees bushings you need. I used the "string" alignment to get the toe-in corrected. It has a little more caster now, but it holds the road a lot better with the front wheels further forward :icon_hornsup: READ camber eccentrics #'s thread for lotta info
thanks guys helped out alot
