Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 12-30-2008, 08:20 AM   #13
feellnfroggy
feellnfroggy's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Used For: DD for right now.
feellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the roughfeellnfroggy is a jewel in the rough
Send a message via AIM to feellnfroggy
Default
Quote:
Originally Posted by dogboy View Post
My truck is doign this eaxct same thign for the past 3 or 4 months ( quite annoying). But mine does it at any speed if I get the throttle in just the wrong spot (a somewhat large spot...).
I've been told to check for intake manifold/ vacuum leak, dirt injectors, and the Throttle Position Sensor, fuel filter, and plugs/ wires. I've changed the fuel filter, and plugs, and the wires tested within spec (7k ohms resistance per foot if I recall) with no change.
I ran a can of Seafoam through a full tank, with no changes at all either. I am probably going to hook a vacuum gauge up to it tomorrow and see what it says (7-8 months ago, it read 18-19psi vacuum, or what ever you want to call it).
After that I am going to check/ adjust the throttle position sensor. I've been told you can adjust it, so I'm just going to figure out how to do that and see what it does.
It could be the TPS going bad. But when it does you will know it. There is no adjusting the TPS. It spins 180degrees based on the position of the intake butterfly. The DIS box can be a problem, In my truck it was the coil for the waste spark (2.3l) I have points 1 and 4 were bad and had to replace it. I still have problems. Check to see if the CPS is dirty. Buy a haynes manual to help with disassemblies and assemblies.
feellnfroggy is offline   Reply With Quote
Old 12-30-2008, 08:25 AM   #14
snake
snake's Avatar
Year: 2002
Make: Ford
Model: The mighty Ranger
Engine: 4.0
Class: 2WD
Used For: cruising for chicks
snake is on a distinguished road
Default
Quote:
Originally Posted by RentonRanger View Post
Sorry for my ignorance, but what's 44K?
Will do.
Its some bad-ass injector cleaner- about $23 or more a can and only sold at stealerships and a few oil change places. Local mechanic turned me on to it, works like a mo-fo. Its supposed to be pure techron.
__________________
2002 XLT in wedgewood blue, 4.0 auto, 4 doors (no waiting) MP3, 3:55 limited slip rear, payload package, factory installed trailer hitch, side step bars. Built 7/31/2002, shipped 8/19/2002, purchased 9/25/2002 sold 8/2011.
2011 F-150 crewcab ecoboost twin turbo. Purchased 7/13/2011
snake is offline   Reply With Quote
Old 01-01-2009, 10:12 PM   #15
RentonRanger
RentonRanger's Avatar
Year: 1998
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4
RentonRanger is on a distinguished road
Default
Well, it seems to have worked itself out. It's running just fine now, no bucking or hitching at all! I'm thinking that maybe the PCM needed to "re-learn" the new DPFE readings and it just took a few days of driving to get it right.
I'll keep you posted if something changes...
__________________
1998 Ford Ranger XLT 3.0 4x4
Magnaflow Cat-Back Exhaust / SCT X-Cal 2 / K&N Cold Air Intake / Screamin' Demon Coil Pack / Underdrive Crank & Overdrive Alternator Pulleys
Clear Head & Corner Lights with Silverstar Ultras / '07 Taillights / Herculiner Bed Liner / Kicker 10" CVR Sub
Kicker ZX 300.1 Amp / Explorer Leather & Power Seats, Center Console, OHC & AutoDim-Headlamp Mirror / 4.10 Gears / 31x10.5x15's
RentonRanger is offline   Reply With Quote
Old 01-02-2009, 08:11 AM   #16
feellnfroggy
Year: 1993
Make: Ford
Model: Ranger
Engine: 4.0L
Class: 4x4
Default
Quote:
So I posted all this stuff. Then I remembered........My 96 probe did this, I remember when I was driving my 92 ranger this weekend, and I knew the problem felt familiar. Then it hit me. MASS AIRFLOW SENSOR. I unplugged mine and the ranger is running better. Not perfect but at least its smoothed out some. Same with my probe. (runnin real rich though.) Go to a junkyard and try to find one or three for cheap, swap them out see if it helps.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
