2003 FX4 Blue Steel Build
Karbuster
Washington
2003 Mostly....
Curb? What curb, I felt a speedbump
Thought id put this in the right place since im making a major update to it anyway!
page is under construction!
My Truck
2003 FX4 4.0l V6 "Blue Steel"
(yes thats a zoolander reference)
Need to tune up the engine, inside and out, I can hear not good noises (probably just an exhaust valve), going to do a couple little power adding tweaks while I'm in there (hell, i may just grab a 5.0 from an exploder)
Completed projects are at the bottom of the list​
Modifications I'd like to make in packages
Kit One
Aftermarket intake ($265)
Aftermarket exhaust (Done!)
Tuner chip ($280)
Throttle Body Spacer ($125)
Kit Two
Torsion kit & 3 suspension lift + 2in body lift
replace front, and if necessary rear, drive shaft (metallic clicking sound emanates from it at low speeds, possibly a welding blob came loose, hopefully it can be removed, if not, shaft will be replaced)
Kit Three
Install second battery in parallel and look into options for backup solar power
Real brush guard (with min 5k lbs winch)
LED Roof Bar ($300-800)
Misc Work to be done that isnt necessary but nice
Install LED Headlights, Fog Lights, Taillights and Third Brake Light
Bed illumination (in progress, back up and running, gotta plan and parts!)
Upgrade audio system (investigating and saving)
New speakers (2/4 done)
New stereo (Done, looking for better one)
Ground loop isolator and embed an aux port in dash (DONE! LOOKS SICK AS HELL!)
Subwoofers & amp (looking at custom building a box and replacing pilot seats)
I also want to install a shortwave cb radio system​
COMPLETED PROJECTS​
Also would like to figure out why door ajar warning comes on when no doors are ajar (found, common problem, gets dirty and stuck)
Cab illumination upgrade (complete, looking to modify)
Side note, would like to replace existing interior lights with led-direct-fit replacements and install more advanced LED Lighting that can change colors and has a remote
Paint Grille either Chrome or Black (New one is Black, staying that way!)
replace existing mirrors with 2006 model year mirrors
(DONE!) (thanks 02Fx4Red!
Off road lights (in behind grille) and backup lights as i do a lot of driving in the county at night (Done!)
Lights off
Lights on
Reverse Floods done!
in doing my research and trying to figure out where to put switches, i realize i dont want to crowd my dash and began looking at other locations in the drivers reach and i stumbled upon this gem by Jim Oaks
INSTALLED! some issues with the temp sensor, would love help!)
Its not 23*F outside...
I had to get new tires due to an incident (tire came apart at 80mph...)
Old Head Images
2003 FX4 4.0l V6
Mostly stock (just got it a couple years ago and haven't been financially able to seriously modify)
Did replace bed as I got in an argument with a power pole a couple winters ago and I won
Need to re/pair/place passenger front fender and bumper due to the power pole fight and some spineless bastard hit my truck and ran
