- Jun 3, 2013
- Automatic
As the title says, i have a 2002 ranger 3.0, automatic, 3.75 open diff with 61,000 miles. gets a bad vibration from the rear around 50, and gets worse up near 70. I have ruled out tires (rotated them around, and even took them off), and the drums. I have replaced both front and rear u-joints. Tires are fairly new, as with drums, and shoes. Its been doing it for a while, so i took rear end cover off and noticed spider gears had some wear/play in them, so replaced them along with the pin. pin still seems like it is a little loose like the carrier has some wear on it. I have tried taking tires off and drums, and running it on jack stands, axle flanges apear to be straight, vibration is still there when i have all that off and on running it up to 45 on jack stands. checked transmission mount, looks good, no vibration from there. any thoughts?
