Confused ! Help !
93Red_Ranger_
Hey guys,
Just the other day i was waiting at an intersection to pull out onto a main road an i put it into neutral and let out the clutch and it stalled out. Started it back up, put in N and same thing. Than i try reversing out of the way and it wouldnt move. So i pushed it into the pizza shop parking lot and went to put in gear and wont go into gear. Not 1st, 2nd, went into 3rd but barely, no 4th, or 5th. Reverse would go in but id give it gas and let out clutch and it didnt want to move. Everyone that i've spoken to said its the throw out bearing. I also heard that it could just be the pin that goes thru all the gears but im not sure. I just want more opinions so i get the right part and get my baby back on the road. With no truck, there's no income. I hope you guys can help, i need my truck back on the road ASAP!
Thanks,
Mike
So from what I gathered, its stuck in 3rd, but the shifter still moves...?
Definitely not a throwout bearing, whoever told you that is seriously mechanically tarded.
That is most definitely an internal transmission problem.
If its hard to get into gear all of a sudden it sounds like a slave or master failure. If you shut the truck off will it drop into all gears?
Sent from my DROID RAZR using Tapatalk 2
