- Sep 14, 2009
- SE Michigan
- Automatic
Hi,
We have trans fluid leaking into our radiator. I was told that this was probably due to the automatic transmission fluid cooler, which supposedly is built into the radiator, is leaking into the radiator, and that the radiator needs to be replaced. Also the thermostat and the block or housing that holds the thermostat is bad, and needs to be replaced as well and that the system needs to be flushed. Does this sound like a correct scenario?
Is it difficult to replace the thermostat? And is there really a separate housing for the thermostat? When I was young and did this on my own, the thermostat was just accessed by taking off the radiator hose from the top of the engine block and dropping in a new thermostat - it was pretty simple a five or ten dollar part. Is there now a separate housing for the thermostat that is somewhere inside or mounted on the outside of the engine block?
I am also assuming, if it is a leaky trans fluid cooler that is built into the radiator, that the transmission should be flushed once I install a new radiator, Is this correct?
