Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Non Truck Discussions > Non RBV Tech
Notices
Non RBV Tech For discussing tech other than Ranger related.
Post New Thread Reply
Thread Tools Display Modes
Old 08-11-2012, 01:52 AM   #1
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Used For: Giving me pride.
koda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to beholdkoda6966 is a splendid one to behold
Default Mower wiring.
Some asshat ripped all the wiring out of my riding mower and stole my gas. Needless to say I need to rewire..
Do I have this right? I'm pretty sure it doesn't have a charging circuit.
STRTR is STARTER by the way. Couldn't fit it. The Start/On switches are standard toggle switches.. the keyed ignition hasn't functioned in quite some time.
Never wired one of these up, seems like a basic concept though.
__________________
1993 Ford Ranger XL Supercab 3.0 V6. Custom interior. Edge Conversion (WIP). 03 Explorer seats. 6" lift (WIP). Sitting on 35x12.5R15 Mastercraft Courser MT's.
1997 Jeep Cherokee Sport. 4x4/4.0/auto. Daily Driver & parts snagger.
Ranger Build Thread.
Jeep XJ Build Thread.
koda6966 is offline   Reply With Quote
Old 08-11-2012, 06:00 AM   #2
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
martin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the rough
Default
The motor on a riding mower should have a charging circuit and they vary depending on what motor it is. There are a few sites on the net that have the circuits on, I know because I had to search around when I changed the motor on mine and lost the diagrams that came with the motor on the way home.
martin is offline   Reply With Quote
Old 08-11-2012, 01:42 PM   #3
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
Hmmm.. that's probably the white wire coming out of the top of the engine going no where. Somebody hacked that off long ago.
__________________
Old 08-11-2012, 02:14 PM   #4
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Model: Bronco 2/Fordenstein
Engine: 2.8/5.0
Class: 4x4
Used For: DD/taking up garage space
dieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud of
Default
Mower brand? Engine?
__________________
Quote:
Originally Posted by PlumCrazy View Post
You can't fix stupid with a wrench though.
Quote:
Originally Posted by 97RangerXLT View Post
I disagree. It all depends on how big the wrench is and how hard you hit stupid with it :P
Add yourself to the TRS MEMBERSHIP MAP!!!!
dieseldane is offline   Reply With Quote
Old 08-11-2012, 02:29 PM   #5
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
It's an old Montgomery Ward with a Briggs and Stratton engine.
I found a basic wiring diagram online but it doesn't match the ignition switch. If I run the wires according to the ignition switches diagram, nothing works.
However, I did manage to somehow get the starter to spin backwards.
I'm switching batteries, I think something's up with this one. It's good that I have a spare.
The wiring diagram online is as follows..
_B_ _S_
_M_ _A_
_G_
However the one on the back of the switch is like this..
_A_ _G_
_S_ _B_
_M_
(A=Accessory, S=Starter, M=Magneto, B=Battery, G=Ground)
It doesn't work in either pattern. However if I mix them around, it turns the starter backwards.
Also, the mower has two different solenoids on it. One is a three post that has no wires going to it (assuming it's bad) the other is a four post. That shouldn't effect anything should it?
__________________
Old 08-11-2012, 04:06 PM   #6
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
Other battery fixed it, I should be all set!
__________________
Old 08-11-2012, 04:11 PM   #7
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
Did you hook the 1st battery up backwards?
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,....
4BT swap thread
Ranger bed trailer build
Scars are just tattoos... with better stories!
snoranger is offline   Reply With Quote
Old 08-11-2012, 11:45 PM   #8
koda6966
koda6966's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD Off-Road
Default
No that was the first thing I checked haha.
Somehow it has reversed it's polarity.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
