Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Styling & Electrical > Heating & Air Conditioning
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 07-04-2012, 10:53 AM   #1
erick sanders
Year: 1994
Make: Ford
Model: Ranger 4x4 4.0L
Engine: 4.0L OHV
Class: 4x4
Used For: work and daily driver
erick sanders is on a distinguished road
Default gets hot when you turn ac on
hello, everyone
i have a 94 super cab auto 4x4 4.0 .
i use this vehicle on a 80 mile mail route twice a week. i can't use the air at all and its killing me . i can use the air on the interstate but if i turn it on in town it starts to get hot. i back flushed the radiator changed the thermostat . i think the fan clutch is fine and the water pump maybe condensor i just don't know .
or could it be low on refrigerant keeping the compressor running and putting a heavy strain on the motor idk . i hate to just start changing parts that gets costly . so any help would be much appreciated.
erick sanders is offline   Reply With Quote
Old 07-04-2012, 12:12 PM   #2
killj0y
killj0y's Avatar
Year: 1996
Make: Ford
Model: Ranger XLT Standard Cab
Engine: 2.3l 4 Banger
Class: 2WD
Used For: DD and light duty
killj0y has a spectacular aura aboutkillj0y has a spectacular aura aboutkillj0y has a spectacular aura about
Default
Sounds like a fan or coolant system issue. Low refrigerant will make it cycle or stay off so I doubt that's more work versus staying on properly
__________________
96 Ranger 2.3l 2WD Manual 5 Speed
*Throttle Cable Mod
*Permanently Fixed Cigarette Lighter
*Snorkel Mod
*4" Rough Country Lift
killj0y is offline   Reply With Quote
Old 07-04-2012, 12:31 PM   #3
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Engine: 2.9 High Performance
Class: 4x4
Used For: Elevenses
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Not to be a dick, but your post tells me that the only thing you really know about A/C is that it makes you cold.
Have a professional look at it.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: 12-Volt Sandwich
Quote:
Originally Posted by Raj
What you need is cheat codes, motor skills, and a magic genie who grants wishes to little boys who suck at Mario Kart
Quote:
Originally Posted by John Adams
Our Constitution was made only for a moral and religious people. It is wholly inadequate to the government of any other.
HELP REPEAL OBAMACARE
Looking for 95-98 manual trans pedal bracket. Conducting an experiment for the betterment of all Ranger-kind.
adsm08 is offline   Reply With Quote
Old 07-04-2012, 01:01 PM   #4
erick sanders
Year: 1994
Make: Ford
Engine: 4.0L OHV
Class: 4x4
Default
NOT A "DICKISH" REPLY AT ALL. extremely helpful and has bounty of knowledge thanks.
Old 07-04-2012, 07:41 PM   #5
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
martin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the roughmartin is a jewel in the rough
Default
Are you sure it's not a Jeep you're driving as that seems to be a very common problem with them.
martin is offline   Reply With Quote
Old 07-04-2012, 08:12 PM   #6
Tracked and Locked
Asteroids Champion
adsm08's Avatar
Year: 1987
Make: Ford
Model: Ranger XLT
Class: 4x4
Used For: Elevenses
Default
Does it get hot hot or just not cold hot? You might have a small leak somewhere.
I will help anyone work through anything they want to try, but I will always tell people to take their A/C problems to a shop. There is just too much equipment you need to have to to the job right that the average person can't afford.
__________________
Old 07-04-2012, 08:34 PM   #7
martin
Year: 1984 1991
Make: ford
Model: b2 explorer
Default
The way I read the op. it sounds like the motor starts to overheat if you get stuck in traffic or just into a drive around town sort of thing. It seems a very common complaint with Jeeps and I've never found a solution. I've never heard of it being an issue with an rbv though.
Old 07-10-2012, 09:58 PM   #8
vanguard
vanguard is on a distinguished road
Default
fan clutch
vanguard is offline   Reply With Quote
Old 07-24-2012, 03:01 PM   #9
Hawk1339
Hawk1339's Avatar
Year: 93
Make: Ford
Model: Ranger
Engine: 3.0
Class: 2WD
Hawk1339 is on a distinguished road
Default
I've been having this same problem this summer. Never had it before this year. We have had an unusually hot summer so that doesn't help. Thermostat is new, cooling system is properly filled. Water pump is maybe 3 years old. AC clutch was new last year, freon is properly filled, system does get cold.
Whatever the outside temperature, the temp gauge holds exactly at the "OR" in "NORMAL" but as soon as the AC is turned on the temp creeps up to the "M" or even beyond.
Hawk1339 is offline   Reply With Quote
Old 07-25-2012, 08:48 PM   #10
Ranger SVO
Ranger SVO's Avatar
Year: 1993
Make: Ford
Model: Ranger
Engine: 2.3 Turbo
Class: 2WD Street
Ranger SVO is on a distinguished road
Default
Lets go with the fan clutch. At highway speeds you have enough air being rammed through the radiator and AC condenser, the fan is not even needed at highway speeds. But at slow speeds the fan is the only thing that draws air through the condenser and radiator.
Its fine at highway speeds but not at slower or stop and go driving tells me we have a problem with the fan.
__________________
The moving power of mathematical invention is not reasoning but imagination.
Augustus de Morgan
Truth does not change because it is, or is not, believed by a majority of the people.
Giordano Bruno
Ranger SVO is offline   Reply With Quote
Old 07-26-2012, 10:18 AM   #11
Gacknar
Gacknar's Avatar
Year: 1989
Make: Ford
Model: Ranger "STX High-Rider"
Engine: 2.9L
Used For: Daily Driver
Gacknar is on a distinguished road
Default
How hot does the coolant actually get?
Have you put a mechanical gauge on it and checked the actual temp?
If you turn the A/C off does the temp go down to a reasonable level?
__________________
1989 Ranger "STX High-Rider" 2.9L/M5OD/BW1350 manual, 3.73:1 gears, 6" lift with 32x10.50R15 BFG Radial Mud terrains on 15x8" outlaw II's
Gacknar is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
