Serving Ford Ranger, Bronco II, Explorer & Mazda B-Series Owners Since 1999
Home Forums Info - Technical Info - Other TRS News Photo Galleries Shirts & Decals Parts Store Classifieds
Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Notices
Need Urgent Help Fast! For posting questions when you're in the middle of working on something and have to have an answer right now.
Post New Thread Reply
Thread Tools Display Modes
Old 07-23-2012, 06:32 PM   #1
2.3
Year: 1995
Make: Ford
Model: Ranger
2.3 is on a distinguished road
Default how to change out ignition cylinder
ive tryed drilling out the pin and drilled straight through the key way. it still wont move out.
2.3 is offline   Reply With Quote
Old 07-24-2012, 12:47 AM   #2
84bluebronco2
Premium Member
84bluebronco2's Avatar
Year: 94
Make: Ford
Model: Explorer
Engine: 4.0
Class: 4x4
Used For: Getting my RBV fix
84bluebronco2 is a jewel in the rough84bluebronco2 is a jewel in the rough84bluebronco2 is a jewel in the rough84bluebronco2 is a jewel in the rough
Default
I seem to remember just pushing the pin and the whole cylinder just slipped out. Is the key in the ignition, and the ignition turned from off?
__________________
Quote:
Originally Posted by doorgunner View Post
BROWN fluid in a transmission IS Roman for 86'd (LXXXVI'd)
Quote:
Originally Posted by snoranger View Post
Someone has to be there to make you a sandwich when you get hungry. She might as well be naked.
91 Ranger 4x2 2.3: RIP 84 BII 4x4 2.8: RIP 94 Explorer 4x4 4.0/M5OD/1354M: DD
84bluebronco2 is offline   Reply With Quote
Old 07-26-2012, 08:48 AM   #3
branflakes613
Year: 1996
Make: Ford
Model: Ranger
branflakes613 is on a distinguished road
Default
You have to have the keys in the run position. If it's broken and won't turn over, you have to do this:
1. Disconnect battery ground cable .
2. Using channel lock or vise grip pliers, twist cap until it separates from the ignition switch lock cylinder .
3. Remove lower shroud.
4. Prick-punch pin and drill out with 1/8-inch bit. Do not drill deeper than 13mm (1/2 inch). Put a piece of masking tape 13mm (1/2 inch) from tip on bit. Take care not to damage housing.
5. Using a 3/8-inch diameter drill, drill down middle of ignition lock key slot approximately 44mm (1-3/4 inch) until ignition switch lock cylinder breaks loose from breakaway base of ignition switch lock cylinder . Remove ignition switch lock cylinder and drill shavings from lock cylinder housing.
6. Remove column lock gear retainer, steering column lock housing bearing (3E700) and steering column lock gear (3E717) . Thoroughly clean all drill shavings and other foreign materials from lock cylinder housing.
7. Carefully inspect lock cylinder housing for damage from the above operation. If damage is apparent, lock cylinder housing must be replaced.
branflakes613 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
© 1999-2012 / 959 Media LLC / All Rights Reserved
[Legal Notices]   [Advertising/Vendors]
Also check out SSP Central for Special Service & Non-Traditional Police & Fire Vehicles
